My car is a shop WOW
Old Jan 23, 2011 | 02:43 PM
5LEEPERISAH23I's Avatar
So i do everything on my car myself, I have had my car for two years now and counting. I just put in a short block and has had trouble with little things ever since. Once it warms up "The Motor it run perfect." It has 127 miles on the new shortblock" When 99% it does not start and just cranks
I just gave my car to JNZ Tuning hopefully they take care of my car and do a good job with it and find the problem because i tired just about every logical think on the car.
Car just cranks, it fires but then instantly stall's it's self out.
Change:
Cam angle sensor
Crank angle sensor
Coil Pack
It is getting fuel
It is getting spark
Timing is set correctly
Checked the compression
Looked for loose or faulty wires "Couldnt find any"
Replaced Battery
Am out of idea's so let see what JNZ can do will update as i hear things
Old Jan 23, 2011 | 02:48 PM
JohnBradley's Avatar
IF the car has any Tephra map on it make sure its not on the Valet map, if its on SD make sure the MAP sensor is working.
Old Jan 23, 2011 | 02:49 PM
wht95scort's Avatar
cam angle sensor out 180?
It will still run but be down about 50whp.
Old Jan 23, 2011 | 02:52 PM
No Tephra, no SD
Old Jan 23, 2011 | 02:53 PM
and nope i checked that also ha
Old Jan 23, 2011 | 03:48 PM
stamlon's Avatar
my guess would be timing, i had a very similar problem .
Old Jan 23, 2011 | 05:30 PM
i hope it is, it might be a tooth of or somthing
Old Jan 23, 2011 | 07:23 PM
BLK_EvIL's Avatar
check the IAC mine did simalar things fire then die unless i played with the gas and once i would drive it and get it warm it would idle worth a shot i picked upa used one on ebay for $40 bucks
Old Jan 23, 2011 | 07:34 PM
yea that is one thing i didnt cheack
Old Jan 23, 2011 | 11:56 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Can you get it to run by opening the throttle while cranking?
Have you done a boost leak test?
I'm thinking it's an air problem. Isn't there a test in the manual for the MAF sensor?
Old Jan 24, 2011 | 04:01 AM
MRGEVO's Avatar
+1, check for boost leaks.
Old Jan 24, 2011 | 06:02 AM
I don't think it is a boost leak bec it runs fine n spool when it does run..
I unplugged the MAF n it didn't seem like that was the problem. I was out of ideas
Old Jan 24, 2011 | 06:11 AM
whitedsm97's Avatar
im with blk evil. my car did the same thing to and i would have to gas it to keep it running. pulled the iac out and it was completely gone up top. while it was running, it would idle real low and almost die unless us gased it. good luck.
Old Jan 24, 2011 | 06:57 AM
AlwaysinBoost's Avatar
x2
I just found a leaking EGR valve that was causing all kinds of idle/stalling/driveability issues. the car was boosting fine on the road, I was hitting 24psi by 3800 RPM in 3rd gear, but it wouldn't hold any pressure at all when I leak tested it. Once that leak was fixed my car was back to driving like stock.
bottom line is that if you haven't leak tested your car recently chances are you've got a leak.
