car wont go on WOT
Old Jan 28, 2011 | 11:01 PM
ch1215g's Avatar
SUSPECTED SCAMMER
car wont go on WOT
So i decided to get on her today and to my surprise as soon as i hit the gas and the turbo starts to spool the whole car like bounces and hesitates to go anywhere. What could this be from. Car was justtuned, spark plugs were changed and boost leak test was done. If i try to log with the accessport itll say logging then when i go wot itll say cant connect to ecu? Thats the other problem. Strange thingsare happening lol.
Old Jan 29, 2011 | 12:33 AM
ch1215g's Avatar
SUSPECTED SCAMMER
bump...
Old Jan 29, 2011 | 07:53 AM
Ogee06's Avatar
I could be totally wrong with my answer but mine did the same thing. I cured it by lowering the boost. When it is much colder weather than when I tuned my car it does this. Basically, with the denser air, I was over boosting. Not sure if your weather affected it or not but just a suggestion.
Old Jan 29, 2011 | 08:03 AM
achilles3000's Avatar
Bingo sounds like boost(fuel cut)..Lower the boost then m.b.c all the way down test then redial the desired boost level for tune.
Old Jan 29, 2011 | 08:19 AM
BLKCarbonEVO's Avatar
I agree, sounds like overboost or your tuner accidentally put you in valet mode. But valet mode is usually set at 3500 so if you can go over 3500 then it is more than likely overboost. Just turn the boost controller down or pull the wastegate line and try another pull.
let us know if it fixes the problem.
Mikey
Old Jan 29, 2011 | 10:00 AM
iluvmydsm's Avatar
check your spark plug gap
Old Jan 29, 2011 | 04:14 PM
ch1215g's Avatar
SUSPECTED SCAMMER
turns out it was a vacuum line that attaches to the fuel rail. It keeps popping off.
Old Jan 30, 2011 | 06:17 AM
stophos's Avatar
When this line pops off you get a lean condition causing the problem you described.
Old Jan 30, 2011 | 06:40 AM
Evoryder's Avatar
A little glue and zip ties for the fpr vacuum line. If it's one of the fuel return lines, then change to a worm clamp.
Old Jan 30, 2011 | 12:33 PM
ch1215g's Avatar
SUSPECTED SCAMMER
Whats code P0090? Fuel pressure solenoid circuit?
Old Jan 30, 2011 | 12:45 PM
Evoryder's Avatar
https://www.evolutionm.net/forums/la...ing-p0090.html
Something related to the leak/line popping off is triggering the code.
Egal44ARock
Jan 1, 2012 09:00 AM
hang187
13
Oct 23, 2009 05:16 PM
joeymia
16
Oct 11, 2005 05:32 PM
