255 WHP w TBE and Boost?
Old Jan 31, 2011 | 10:26 AM
Camrymatic's Avatar
Quick confirm, do these look like decent numbers?
Stock 2003 evo except TBE ( high flow cat), LICP, Mechanical Boost, Tune, K&N High flow in stock box.
255WHP / 320 WTQ on Mustang Dyno.
Old Jan 31, 2011 | 10:34 AM
4RETECH's Avatar
What?? That's with a tune?? How much boost??
Old Jan 31, 2011 | 10:36 AM
newbieEVO8's Avatar
If it is a normal low reading Mustang dyno.
CAD EVO's Avatar
Yea, we need to see the boost level to give you any indication of how good those numbers are.
Thats alot of torque for the HP number.
Old Jan 31, 2011 | 10:37 AM
Donkeypuncher's Avatar
Seems low, I dynoed more than that stock. Id be looking for a boost leak. Depends on the dyno also. Did anybody else that used that dyno experience disappointing numbers?
That being said, I did a ton of work to my car and only went to 275. Different dyno also though (DynoJet that reads very low). That was after adding tune, ported mani, TBE, O2, MBC, walboro and new tranny and clutch.
Old Jan 31, 2011 | 11:08 AM
Camrymatic's Avatar
Yea, i have limited experience with that Dyno, but after my car, they tuned a ralliart (2010) and it was stock, and they got 250-260 whp.
Hold the opinions on the TQ number though, i dont have the dyno sheet in front of me, but i recall TQ being over 300.
Peak Boost is set at around 21 i believe.
Old Jan 31, 2011 | 02:16 PM
J.J4ck0wsk1's Avatar
Yeah boost is low, get an Evo 9 turbo and bov (if you don't have a decent bov already) and go to a different dyno. Should be well in the 335 whp zone with those mods and a 9 turbo if not higher..
Old Jan 31, 2011 | 02:18 PM
Where did you get dynoed by the way?
Old Jan 31, 2011 | 02:26 PM
EvoDom's Avatar
That seems way to low. I would deffinetly go to a different dyno. Keep in mind mustang dyno's read lower than dynojets.
Old Jan 31, 2011 | 02:28 PM
tscompusa2's Avatar
only 255whp? sounds like a bad tune since theres more hp to get. what fuel is it? sounds like they dialed in the mid range and nothing uptop.
Old Jan 31, 2011 | 03:10 PM
Camrymatic's Avatar
The tune was a TTP dynoed at Central Florida Turbo. The gas was 93.
Maybe their dyno reads lower, i need to find out on "Florida Evo Club".
Looking at the graph Peak HP hits at about 4.5k but i remember hearing that the dyno might be off there.
My TQ is 367 though, that seems awful high even with a margin of error built in. Its up there from 2.5k-3.5k
Old Jan 31, 2011 | 03:58 PM
Go to AWD Motorsports. Torque seems way too high for hp output. Post up a graph because it doesn't sound like it would look very smooth. Don't want that torque all at once, but to come on smoothly because you'll start breaking things.
Old Jan 31, 2011 | 04:04 PM
CJ2X's Avatar
Originally Posted by Camrymatic
The tune was a TTP
That's why.
Old Jan 31, 2011 | 04:57 PM
Camrymatic's Avatar
Here is the sheet.
Old Jan 31, 2011 | 06:37 PM
I'm no expert, but that graph doesn't look good at all..
