Question about torque..
Old Feb 15, 2011 | 03:14 PM
VKEVO's Avatar
Hey folks, I got a dyno tuned recently and my car made 346 torques but somehow I don't really feel that torque when I drive it. For example, when i take off in 1st gear it feels like it's not that fast (even a jeep wrangler passed me) I wasn't boosting, I just drive it up to 3500 rpm then shifted to 2nd gear. Is this the way our car is designed, is it not suppose to move fast unless you go into boost?? I got a tune already and I can't think of anything else. It's on a stock turbo btw, I don't want to hit 4000rpm everytime i take it off from first gear, but it seems like I have ppl right behind my car if i shift at around 3200rpm. Can you guys think of anything? Anything would be helpful. Thanks a bunch.
Old Feb 15, 2011 | 03:21 PM
SW20Mike's Avatar
Veteran: Air Force
I'd say you're gonna be slow off the line to a Jeep Wrangler gunning it vs you just driving leisurely to 3500Rpm and shifting. 2.0 liter turbo isn't going to have much grunt down low, and if you aren't in boost you aren't making much power. I'm sure your car is fine, its just you driving leisurely and everyone around you trying to get going in a rush.
EvoJoeIX's Avatar
wow... you have got to be kidding me
look at your dyno chart and you will see where you will hit full torques(haha)
turbo cars make no power unless your in boost
Old Feb 15, 2011 | 03:24 PM
fishie36's Avatar
that 346 lbs of torque is at WOT probably between 4-5000RPM. Try going WOT in first gear in that rpm and then tell me you dont feel the torque
Old Feb 15, 2011 | 03:31 PM
Bramage_Dained's Avatar
This thread will be full of lulz by the weekend.
Old Feb 15, 2011 | 03:40 PM
VKEVO's Avatar
Thanks for the info guy, and if any of you want to call me a noob it is fine with me. I just switched from a rsx so I expected a lil more out of the evo but now I do know what it's really is.
Old Feb 15, 2011 | 04:00 PM
PDCC_EVO's Avatar
Think about this quote a second. I doubt they granny drove your car during the tune. If you arent boosting the car your not going to feel a lot of tourqe nor is it going to accelerate quickly.
Old Feb 15, 2011 | 05:09 PM
EvoJoeIX's Avatar
someone needs to re read....
Old Feb 15, 2011 | 05:26 PM
Jrah2987's Avatar
Veteran: Air Force
This car lives (and dies) by the turbo.
Out of boost = WTF
In boost = OMFG
Old Feb 15, 2011 | 05:39 PM
savagejay1's Avatar
Simply put, if you are not boosting you are just driving a car with a 2.0l engine.
Also, your power depends on how much you are pushing down the throttle.
Example: If you are at half throttle and no boost you will be making more power than at quarter throttle and no boost.
Old Feb 16, 2011 | 03:50 AM
It just, you talk about shifting early. These are slow until the turbo spools. 33-3500rpm is where the fun starts, below that is bleh.
Just driving around I usually shift at 45-5000 which is enough to get a taste of fun, "spirited" driving is ~7000.
Old Feb 16, 2011 | 04:00 AM
recompile's Avatar
If you think that's bad, try driving my car. ::sigh:: I miss the stock turbo sometimes.
Old Feb 16, 2011 | 04:23 AM
hotrod2448's Avatar
You are not driving a big block chevy. It's not going to have gobs of power down low in the RPM range. To make matters worse to be able to run the boost the Evo does the compression ratio is pretty low which makes it even worse when off boost. So yes, if you want it to feel fast you have to go into boost.
