The bastards broke into my Evo!!!
Originally posted by SoR
All remote starts I know of either remove the factory immobilizer system and replace it with aftermarket or require you to leave the key in the ignition - thus eliminating your kill switch feature.
I would never get it.
Originally posted by LateSleeper
I find that false depending on what alarm systems you are refering to. Your "high" quality alarm/remote start systems will require a donar key. This is kept in a seperate transponder box hidden deep in the car. The stock immobilizer system works with the aftermarket alarm. When the alarm tries to remote start the car, the alarm will go to the transonder box with the donar key and use that key's signature to start the car. When you get to the car, you then have to insert your key into the ignition. If you press the brakes or push the e-brake down without putting the key in the ignition the car shuts off. Aside from all that, a thief would have to bypass the wiring for the stock immobilizer and aftermarket alarm.
I'm curious to know what is the alarm system you're reffering to because I'd be interested myself.
Everything you wrote here sounds awesome.
Thx.
I have the Viper 791 2-way with remote start and turbo timer. My installer got the remote start working perfectly on my Evo. He installed a neutral safety switch so the car will not remote start if the car is in gear. I believe he used a magentic switch in the shifter.
Getting a good alarm installed is well worth the piece of mind.
Originally posted by Kayaalp
Why's that?
Christmas shopping?
Why's that?
Christmas shopping?
Kayaalp, sorry to hear about that...your car is creating quite a buzz here in Montreal. You were obviously the guy posting on montrealracing weren't you? We'll your car will continuously be a prime target here unfortunately and i wouldn't rule out those thieves coming back for another crack at it. I'll tell you one thing though, if I see your Evo parked downtown somewhere and i see punks messing with it, I will be glad to assist you in kicking some a$$...as a reward, u can take me for a ride
. Well, I'm having a Boomerang and alarm installed this week. Let's hope the same people try to break into it again so they get nailed. Maybe I can recover some of the costs of this repair...Emre
Re: Huh
Originally posted by xphillipjrx
What's a Boomerang?
What's a Boomerang?
Emre
