Replace clutch before tune?
Old Feb 18, 2011 | 12:48 PM
TxFAkuma's Avatar
I DO KNOW my clutch is going bad... because when i start driving and i push the pedal down and then i try to go into another gear my RPM'S goes flying too 6k before it drops and grabs... But my question is SHOULD i replace the clutch before the tune? I do think i need to... but im not sure if its necessary... the cost of a clutch replacement is expensive.
Thank You.
Old Feb 18, 2011 | 12:54 PM
evo8john's Avatar
Almost sounds like you may just need to adjust it a little. have you tried that?
Old Feb 18, 2011 | 12:56 PM
blknblubkrdude's Avatar
You're right, it should be replaced. The tuning session will be worthless if the power cannot transfer to the dyno's rollers.
My first tune I had stock clutch. When I install my new turbo I am going to put a new clutch in too, just to be safe, as I have to travel at least 350 miles for a dyno session.
To have a professional do it, you will be looking at 500-700 dollars. If possible, have a shop that specializes in Evo's do it.
Good luck!
Old Feb 18, 2011 | 12:57 PM
Jrah2987's Avatar
Veteran: Air Force
Yes, replace it first.
Just try to do flywheel, throw out bearing, lines, and whatever else you want to do while you're in there to try and save some money.
Old Feb 18, 2011 | 01:00 PM
Alexl08's Avatar
Originally Posted by Jrah2987
Challenger R/T: "I bet that POS can't even burnout"
Me: *Smirk* "You're absolutely correct"
This made me smile.
Old Feb 18, 2011 | 01:10 PM
Earthen's Avatar
Replace for sure.
Old Feb 18, 2011 | 01:15 PM
CJ2X's Avatar
I had the same question a while back and this is what AWD told me:
Originally Posted by AWD Motorsports
Correct the car cannot get a proper tune if its slipping thru the RPM range..
Mike
Old Feb 18, 2011 | 01:25 PM
edogg23's Avatar
Not only will it not tune right but once it starts slipping like that it is only a matter of time before your car is going to not be drivable anymore. Get the clutch fixed before you have to get it towed to a repair shop.
Old Feb 18, 2011 | 01:57 PM
GgreyEVOIX's Avatar
Replace the clutch for sure if it's slipping.
I was in the same situation when I was getting my first tune and I went ahead and replaced the clutch, flywheel, and all the drivetrain fluids.
Old Feb 18, 2011 | 02:21 PM
polish_pounder's Avatar
What if your not sure if your clutch is going bad? i have no problem with my clutch grabbing but i tried to launch a few days ago and i dont know if i just suck at it or if its slipping because it wouldn't grab. but it drives fine so should i replace before my tune?
Old Feb 18, 2011 | 06:48 PM
edogg23's Avatar
As long as it doesn't slip when you don't launch it you should be fine.
Old Feb 18, 2011 | 07:56 PM
blaze-619's Avatar
Replace for sure.
Old Feb 18, 2011 | 11:46 PM
jtbell86's Avatar
ahh yes, had this exact problem today. I wasnt sure if my clutch was slipping or not. I got to the shop to get an E85 tune and on the FIRST pull the clutch slipped so bad we had to abort. Now we waisted both our time and my car is sitting in his shop waiting for a clutch, then I can get tuned. So to answer your question, yes please replace your clutch before getting a tune. I speak from experience.
Old Feb 18, 2011 | 11:48 PM
jtbell86's Avatar
Esp if you have mods, if your trying to make any decent numbers and on a stock clutch you really dont stand much of a chance if you are higher up in mileage.
Old Feb 19, 2011 | 12:19 AM
CJ2X's Avatar
Take it to a hill and hit the gas, if you're RPM's start going all over the place even when your foot is steady on the pedal; You clutch is slipping.
