Part number for o-ring for the throttle body
Old Feb 18, 2011 | 06:30 PM
rtsr's Avatar
I need the isc o-ring part number and the o-ring that is inside the throttle body on the side.
Thanks
Old Feb 19, 2011 | 04:37 AM
rtsr's Avatar
Any one know?
Old Feb 19, 2011 | 05:11 AM
bigben's Avatar
I always PM RussellM for any oem part inquiries
Old Feb 19, 2011 | 05:28 AM
Bobster22388's Avatar
All of the part number requests go in here : https://www.evolutionm.net/forums/ev...t-go-here.html
A lot more likely to get an answer there.
Old Feb 19, 2011 | 05:35 AM
rtsr's Avatar
Ok ill try there, thanks.
Old Feb 20, 2011 | 01:40 PM
rtsr's Avatar
Any one know, i can't seem to get an answer.
Old Feb 20, 2011 | 02:02 PM
joseph143's Avatar
call you local dealer parts department... thats probably where you're gonna have to purchase it anyway. i havent seen to many companies selling TB o ring kits...
Old Feb 20, 2011 | 02:14 PM
evo8426's Avatar
you can not get the o-rings separate from the throttle body through the dealership. i would suggest to go with the milspec throttle body seals. picture did not load for me the 1st time seeing the thread so i dont think the milspec seals are what you need.
Old Feb 20, 2011 | 03:37 PM
rtsr's Avatar
This is the o-ring i need, just wondering if anyone new what is was off hand. If not i will go to the dealer tomorrow.
Old Feb 22, 2011 | 07:52 AM
rtsr's Avatar
Dealer said they can't get the o-ring... I guess im just going to measure it myself and find one.
Old Feb 22, 2011 | 11:11 AM
rtsr's Avatar
Does anyone know what this part is called?
Old Feb 22, 2011 | 06:15 PM
joseph143's Avatar
actually the other guy had a good point... mil spec or whoever else ports the tb might have em... since the break down the tb almost completely they probably have some of these on hand... you might wanna call them and ask. if not a decent oring kit should have it...
Old Feb 25, 2011 | 08:00 AM
rtsr's Avatar
Ya i found the o-ring but does anyone know what to call that part.
Old Feb 25, 2011 | 01:39 PM
Boosted Tuning's Avatar
I would say go to your local auto parts store. They usually have a assorted o-ring set in metric and in standard. Buy both and then just find one that fits best.
Old Jan 30, 2012 | 02:02 PM
10isace's Avatar
Mine is leaking as well. What did you end up doing and did you figure out what that part is called and what it does? I ended up spending over $200 for a new TB. I measured my o-ring at 7mm id and 8mm od. I need to measure the thickness of the ring too.
