EVO 1-9 Information
Old Feb 22, 2011, 11:01 AM
Jake26's Avatar
EVO 1-9 Information
Not sure where i should post this.. mods move it if neccesary or sticky it..
Lancer Evolution Information - EVO 1/EVO I
In October of 1992 the EVO 1 went on sale with 2,500 examples being available to meet Group A Rally homologation rules. The first 2,500 cars sold out in 3 days which led to Mitsubishi making another 2.500 cars. The differences between the normal road going Lancer and the Lancer Evolution were huge. The 4G63 powerplant was thoroughly updated with improvements being made to the breathing, turbo, fuel injection as well as the engine internals. A larger front mounted intercooler was installed which included its own water spray system.
Although these changes only gave the car an extra 10bhp the engine was well capable of handling more power. As would be expected with a rally car the body shell was extensively stiffened to cope with the rigors of the Safari and Acropolis Rally's. The EVO 1 came with a viscous centre differential and a limited slip diff at the rear.
The GSR version was the more focused version and this came with air conditioning, Recaro seats, Momo steering wheel. tinted glass, abs, electric windows and mirrors plus a 6 speaker car audio system. The body work also had to comply with the rally regulations which meant all the scoops and vents which would be used to full effect on the rally car were also present on the road going version of the Lancer Evolution.
The RS EVO was much more focused on the rally stage meaning that it came without ABS, air conditioning, the Recaro seats and the alloy wheels found on the GSR. Instead the RS came with steel wheels and the result of the systems being left off the RS led to a 70kg reduction in weight.
Lancer Evolution 1 Specs:
Engine: 1997cc
Power: 250PS @ 6000rpm
Torque: 228lbs/ft @ 3000rpm
Weight: 1240kg (RS 1170kg)
Top Speed: 143mph
0-60 mph: 5.1 seconds
Lancer Evolution Information - EVO 2/EVO II
Although the EVO 1 proved extremely popular there were many areas that were improved upon for the EVO 2. The EVO 2 went on sale in December of 1993 and had a production run of 5000 examples, these took just 3 months to sell out.
The improvements of the EVO 1 started with the chassis, the track and wheelbase were increased to give better stability and cornering performance for the road car and the rally car, these track changes allowed the EVO 2 to wear 205/60-R15 tyres without rubbing. The torsional rigidity of the EVO 2 was increased by 30 percent over the EVO 1. Engine power was increased by another 10bhp with the use of a redesigned performance exhaust system and an increases in boost pressure. The gearbox and clutch were uprated and the rear LSD changed meaning that the RS and GSR versions both used the same item. On the outside there was a lower front bumper and an extra element was added to the rear wing. The interior saw even more supportive Recaro seats. The RS now came with same Momo steering wheel as the GSR.
Lancer Evolution Specs - EVO 2/EVO II
Engine: 1997cc
Power: 260PS @ 6000rpm
Weight: 1250kg (RS: 1180kg)
Top Speed: 147mph
0-60 mph: 5.0 seconds
Lancer Evolution Information - EVO 3/EVO III
The EVO 3 was released in January 1995 again with 5,000 examples being available with these being bought up faster than the EVO 2. The exhaust systems was upgraded again for the EVO 3 as a new TD05-16G6-7 turbo was used, this along with a slight increase in engine compression led to a 10bhp power rise. Cosmetically the front of the car was opened up dramatically leading to a much more aggressive look. These changes gave much better cooling not only for the intercooler and engine but also for the brakes. To compliment the new look at the front new side skirts were adopted along with a new rear bumper and new, higher rear wing.
Lancer Evolution Specs: EVO 3/EVO III
Engine: 1997cc
Power: 270PS @ 6250rpm
Weight: 1260kg (RS: 1170kg)
Top Speed: 149mph
0-60 mph: 4.9 seconds
Lancer Evolution Information - EVO 4/EVO IV
Mitsubishi were really starting to hit their stride with the EVO 4, this version was built on the new model Lancer which was released in October 1995 with the first batch of 6,000 EVO 4's arriving in July of 2006. This number was increased to a total of 9,00 cars as the first batch sold out within three days.
In the EVO 4 the engine was turned through 180degrees to the now familiar transverse layout to allow the use of a new 4wd system. The 4G63 motor in the EVO 4 was the first to use a red cam cover. The engine was also revised with new internals and turbo. The new engine hit the Japanese power ceiling of 280ps with torque increasing by 14 percent. The new turbo was a TD05HR-16G6-9T which was connected to the engine with a newly designed exhaust manifold and downstream to a new higher flowing exhaust system. As the EVO 4 was built around the new Lancer the external differences were many with new bumpers, side skirts and a hoop rear wing in contrast to the previous versions which used a rear wing with a separate element. The EVO 4 saw the first version of Mitsubishi's Active Yaw Control (AYC). The first version only acted on the rear diff and allowed the torque output to be altered from left to right depending on the attitude of the car. This change basically led to increased traction out of corners and was probably the single biggest improvement made to the Lancer Evolution up to the present day with the later versions using more sophisticated versions of this original AYC system.
The weight of the EVO 4 also increased as did the size of the brake sand the stiffness of the body shell. The GSR got a Momo steering wheel which now incorporated an air bag, passenger side air bag, white faced instrument cluster, new Recaro seats and a bolt on strut brace. The RS version came with a Momo steering wheel minus the air bag.
Lancer Evolution Specs: EVO 4/EVO IV
Engine: 1997cc
Power: 280PS @ 6500rpm
Torque: 260lbs/ft @ 3000rpm
Weight: 1350kg (RS 1260kg)
Top Speed: 145mph (RS: 128mph)
0-60 mph: 4.8 seconds (RS: 4.4 seconds)
Viki Butler Henderson - Fifth Gear EVO 6 vs EVO 9
Lancer Evolution Information - EVO 5/EVO V
Mitsubishi really went to town on the EVO 5 exploiting many more of the Group A rally regulations. Body work and chassis dimensions were increased to the maximum allowed by the Group A regulations. The wider track meant the EVO 5 had to have flared wheel arches to cover the wider 7.5 inch OZ alloy wheels. The bonnet was now home to the largest bonnet vent allowed by the regulations and the rear wing now had two elements.
On the suspension side camber adjusters were now incorporated as standard and new inverted type suspension struts were now used. The EVO 5 also got a new power steering pump which saved a few kgs over the old design. The engine was again revised with new pistons, a new turbo, new intercooler as well as the cooling system allowing the extra torque of this car to be delivered reliably both on the special stage and on the road. Bigger Brembo brakes were used which included 320mm diameter discs and 4 pot calipers with 300m solid discs being found at the back clamped by 2 pot Brembo calipers. The RS came without ABS and came with steel wheels and the same brakes found on previous EVO's leaving it open to buyers to choose their own brake set up.
Lancer Evolution Specs: EVO 5/EVO V
Engine: 1997cc
Torque: 274 lbs/ft @ 3000rpm
Weight: 1360kg (RS: 1260kg)
0-60 mph: 4.8 seconds (RS: 4.4)
Mitsubishi Evolution Information - EVO 6/EVO VI
The EVO 6 looked basically the same expect for a few minor revisions which increased stability and downforce, these were to comply with the new WRC regs. Again the cooling system was further revised which included a new external oil cooler. On the RS the turbo was changed to a TD05HRA-16G6-10.5T item which used a titanium turbine impeller to reduce weight and for increased strength. Both cars were given a better flowing intake pipe. Chassis modifications included forged aluminium suspension arms, extra spot welding, thicker steel and improved adhesive to increase strength and torsional rigidity. The EVO 6 also came with a new design of alloy wheel in the same size as he EVO 5. The interior had blue detailing in the form of stitching, materials and gauge cluster faces. MOMO steering wheel and Recaro seats were still included in the GSR.
Lancer Evolution Specs: EVO 6/EVO VI
Engine: 1997cc
Torque: 275lbs/ft @ 3000rpm
Top Speed: 150mph (RS: 128mph)
0-60 mph: 4.4 seconds (RS: 4.2 seconds)
Mitsubishi Evolution Information - EVO 6 Tommi Makinen Edition
Unlike most car manufacturers where special editions have only superficial differences from the rest of the model line-up the Tommi Makinen Edition included some core improvements over the standard EVO 6. This included a new TD05HRA-15GK2-10.5T with a titanium turbine wheel, a quieter exhaust system, 10mm lowered suspension and a quicker steering rack. The front bumper lost the large driving lights and were replaced by large vents. The Makinen edition came with Enkei 17inch alloy wheels. 2,500 were made with many believing this to be the best example of the EVO line.
Engine: 1997cc
Top Speed: 150mph
EVO 6 Ralliart Special Editions
RS II - RS version with some GSR extras
RS Sprint - 320PS with special ECU, exhaust and air filter.
RSX - GSR/RS cross over, no AYC or ABS but with electrics
ZeroFighter (eXtreme UK): 340ps, red and white colour scheme
RS450: Based on RS II with 380PS and 390lbs/ft.
Mitsubishi Evolution Information: EVO 7/EVO VII
Available in January 2001 and controversially based on the Cedia platform the EVO 7 was heavier, bigger and less focused than previous versions. The engine in the EVO 7 featured hollow camshafts and a magnesium alloy cam cover to reduce weight at the top of the engine. The biggest improvement came with the update of the AYC which now worked with the ABS and had manually selectable settings of Snow, Gravel and Tarmac. The chassis was reworked but still used MacPherson struts at the front and multi link suspension at the rear. Mitsubishi claimed that the EVO 6 was a better handling car than the Tommi Makinen edition but many disagree. The interior got super supportive Recaro seats a new design of MOMO steering wheel with the rev-counter now placed centrally in front of the driver but unfortunately tyre car lacked auxiliary gauges. A redesigned rear spoiler was evident which increased downforce without increasing drag.
Mitsubishi Evolution Specs: EVO 7/EVO VII
Engine: 1997cc
Torque: 282lbs/ft @ 3000rpm
Weight: 1400kg (RS: 1320kg)
Top Speed: 157mph
0-60 mph: 4.9 seconds (RS: 4.7)
Other EVO VII's
RSII: Half way between GSR and RS
RS Sprint: 318hp, 327lbs/ft
GT-A: More weight, less torque, semi auto gearbox
Extreme Autos: 339bhp
Extreme S: 357hp
Extreme SC: 458hp
2 Official versions in the UK: RSII & FQ-300 RSII equivalent of GSR
HKS Hipermax EVO 8 at Tsukuba - Second half shows the inboard
Mitsubishi Evolution Information: EVO 8/EVO VIII
Restyled exterior but with the new Super AYC.
Mitsubishi Evolution Specs: EVO 8/EVO VIII
Engine: 1997cc
Weight: 1410kg
Top Speed: 157mph
0-60 mph: 4.7 seconds
Mitsubishi Evolution Information: EVO 8 MR/EVO VIII MR
Billed as the ultimate EVO 8. Came with an aluminium roof, lightweight suspension, Bilstein dampers, anthracite alloys, carbon fibre rear wing element.
Mitsubishi Evolution Specs: EVO 8 MR/EVO VIII MR
Engine: 1997cc
Weight: 1400kg
Top Speed: 157mph
Mitsubishi Evolution Specs: EVO 8 VIII 260/EVO VIII 260
Engine: 1997cc
Power: 265PS @ 3600rpm
Torque: 262lbs/ft @ 3200rpm
Weight: 1470kg
Top Speed: 157mph
0-60 mph: 5.9 seconds
Mitsubishi Evolution Specs: EVO 8 FQ-330/EVO VIII FQ-330
Engine: 1997cc
Power: 335PS @ 6800rpm
Torque: 315lbs/ft @ 5000rpm
Weight: 1410kg
Top Speed: 157mph
Mitsubishi Evolution Specs: EVO 8 FQ-340/EVO VIII FQ-340
Engine: 1997cc
Power: 345PS @ 6200rpm
Torque: 320lbs/ft @ 4985rpm
Weight: 1400kg
Top Speed: 157mph
0-60 mph: 4.3 seconds
Mitsubishi Evolution Specs: EVO 8 FQ-400/EVO VIII FQ-400
Engine: 1997cc
Power: 410PS @ 6700rpm
Torque: 355lbs/ft @ 5400rpm
Weight: 1400kg
Top Speed: 175mph
0-60 mph: 3.8 seconds
Mitsubishi Evolution Information: EVO 9 /EVO IX
MIVEC, Mitsubishis innovative variable valve timing technology was first seen on the EVO 9. In Japan the GT replaced the RSII. An estate version was also available. In the UK only FQ models were available.
Mitsubishi Evolution Specs: EVO 9 /EVO IX
Engine: 1997cc
Power: 286PS @ 6500rpm
Torque: 289lbs/ft @ 3500rpm
Weight: 1400kg (RS: 1310kg)
Top Speed: 157mph
0-60 mph: 4.4 seconds (RS: 4.2)
Mitsubishi Evolution Specs: EVO 9 FQ-300/EVO IX FQ-300
Engine: 1997cc
Power: 305PS @ 6950rpm
Torque: 297lbs/ft @ 4400rpm
Weight: 1400kg
Top Speed: 157mph
Mitsubishi Evolution Specs: EVO 9 FQ-320/EVO IX FQ-320
Engine: 1997cc
Power: 326PS @ 6700rpm
Torque: 305lbs/ft @ 4300rpm
Weight: 1400kg
Top Speed: 157mph
0-60 mph: 4.5 seconds
Mitsubishi Evolution Specs: EVO 9 FQ-340/EVO IX FQ-340
Engine: 1997cc
Power: 345PS @ 6800rpm
Torque: 321lbs/ft @ 4600rpm
Weight: 1400kg
Top Speed: 157mph
Old Feb 22, 2011, 11:06 AM
Jrah2987's Avatar
Nicely done sir.
Old Feb 22, 2011, 11:08 AM
03evo8racer's Avatar
really nice write up man.
Old Feb 22, 2011, 11:11 AM
CJ2X's Avatar
How is the IX FQ 300 0-60 worse than the regular IX?
Old Feb 22, 2011, 11:14 AM
PKEVO8's Avatar
nice work, it's cool to see how the evo has truly evolved
Old Feb 22, 2011, 10:10 PM
2.3L's Avatar
Nice way to take people down history lane!
Old Feb 22, 2011, 11:16 PM
DragonDog's Avatar
And I'm happy to say that I've personally seen every model
Old Feb 22, 2011, 11:19 PM
evolutme's Avatar
Very nice write up! theres some good information in here!
Old Feb 23, 2011, 12:51 AM
skimskim3074's Avatar
yup, great inf for sure.
Old Feb 23, 2011, 01:28 AM
MR. EVO MR's Avatar
How many 8 mr's did they send to the US?
Old Feb 23, 2011, 02:01 AM
FJF
FJF's Avatar
Heh, the OP didn't write this. Can't you guys tell just by the way it reads and its emphasis on the UKDM? Regardless, here's the identical text from some random web sources:
http://www.strikeengine.com/mitsubis...ion-specs.html
http://www.subevosky.comes1st.com/evo/evohistory.shtml
There are dozens of these, all with the same exact text. C'mon.
Old Feb 23, 2011, 02:05 AM
FERNO's Avatar
Good work.
Saves me from having to go back and forth to the wikipedia page.
Old Feb 23, 2011, 11:35 AM
Jake26's Avatar
good catch,, true i didnt write that info, but i thought i was valuable to some so i posted it.
Old Feb 23, 2011, 11:49 AM
Kasaper's Avatar
Damn Good Write Up!!! Thanks for sharing!!
Old Feb 23, 2011, 06:55 PM
4G63kevin's Avatar
Sweet info
Quick Reply: EVO 1-9 Information
