RPMs eratically dropping
Old Feb 26, 2011 | 11:44 AM
CJ2X's Avatar
Here's a quick video of mine.. It happened around 3-4 seconds. Car feels like it wants to die, it normally happens after I've been driving for a while and then come to a stop.
Old Feb 26, 2011 | 12:39 PM
grayw's Avatar
Open up Evoscan, select actuators and depending on version you are using either select SAS mode on early versions or Speed Adj, Screw mode on later versions.
Once the actuator is engaged the idle will either raise or fall, with what you describe would imagine the car will probably stall or come close to it. Turn the BISS screw until you achieve an idle of around 850 rpm with the actuator engaged. Once you have done this release the actuator, switch off ignition and reset the battery.
Originally Posted by BlackDismay
So should I try messing with the screw a bit more? Because when i start bringing it up i hear more and more start to escape and make hissing sound get louder. Im not sure if im bringing it up too high or not. If it helps any, the old IAC valve broke on the previous owner so he decided to go cheap and just put the screw all the way in and it was idling at 1,500. Not sure if this could of led to further issues.
Old Feb 26, 2011 | 04:10 PM
dza's Avatar
dza
I've been having a similar problem with RPMs dropping low enough that the engine dies. It only happens right after I start the car. Once the engine is warmed up a little I have no idle problems.
Old Feb 26, 2011 | 07:09 PM
Stock-ish's Avatar
weird.. my 99 mits gsx would do that sometimes, never figured it out.
but my evo actually idles high when i come out of gear..but only to 1500 or so.
then it comes down in 1 or 2 seconds. but i got cams and a DSG tune.
i hope you figure it out.
Old Feb 26, 2011 | 07:40 PM
BlackDismay's Avatar
I have greddy RS blow off valve. so yes. Zeus I think the answer to your question is no because that just completely takes away from the IAC sensor working and will cause your car to idle iratically to around 2k+ RPM's. This is what happened to me after i installed my new sensor.
Old Feb 27, 2011 | 12:30 PM
03upstatefire's Avatar
Ik might sound simple but I've heard numerous times that sometimes with 4g63's the bov to atmosphere causes this trouble. I had the same problems with my 98 gsx before I had the evo.
Old Feb 28, 2011 | 03:13 PM
dvd_mi's Avatar
I have the same problem with no CEL. Take a look at the video:
http://www.youtube.com/watch?v=Bfc_Mbbq_uM
After replacing IACV problem did not disappear. How should it behave with screw all the way in, because mine idles at 820-880.
Old Feb 28, 2011 | 06:43 PM
dza's Avatar
dza
Wow your problem seems much more severe and persistent than what I am experiencing. Also my problem seems to be diminishing with this warmer weather.
Old Feb 28, 2011 | 06:50 PM
1d10t's Avatar
My issue was injector related
Old Feb 28, 2011 | 08:47 PM
David you have the exact same issues mine is having! And i even stall half of the time as well..
Old Feb 28, 2011 | 09:01 PM
white_evo27's Avatar
mine only does this sometimes when its not completely warmed up.
Old Feb 28, 2011 | 09:33 PM
Same problem with my evo when dealing with tight traffic or just creeping forward, seems to only happen when the rps's fall from approx the 2k range. Will stall once in a while but the issue itself happens irregularly.
Old Mar 1, 2011 | 05:03 AM
dvd_mi's Avatar
Anyone had that issue and solved it???
Old Mar 1, 2011 | 09:02 PM
I still have not found out the issue.
Things to try - Retune, Boost Leak, New Blow Off, Adjusting idle under Evo Scan, possible bad injector?
Old Mar 2, 2011 | 04:57 AM
dvd_mi's Avatar
If I take the IACV out of throttle body and turn ignition on, how much should it move (distance). How many times should it do it???
