RPMs eratically dropping
Old Mar 2, 2011 | 05:01 AM
  #31
grayw's Avatar
Have you not used the procedure I described in post #17, it will save you a lot of hassle.
Old Mar 2, 2011 | 05:53 AM
  #32
Earthen's Avatar
I also got this problem...and my car has stalled out during turns and coming to stop lights.
Old Mar 2, 2011 | 08:22 AM
  #33
andrewzaragoza's Avatar
a friend of my had the same exact issue. he replaced his plugs and that fixed it. you can try that if you are due to replace it.
Old Mar 2, 2011 | 08:53 AM
  #34
BlackDismay's Avatar
Plugs have been replaced twice. It's not the plugs. and grayw I'm going to try your method out just seems like a lot of others are offering solutions as well so Ill start basic and move from there.
Old Mar 2, 2011 | 09:56 AM
  #35
tonyboy's Avatar
could be vacuum leak..
Old Mar 2, 2011 | 10:42 AM
  #36
Hemply's Avatar
I'm a mechanic and my shop has a snap on scanner called MODIS. Had a similar issue with crappy rpm's. Put in plugs and no change. Threw it on the scanner and was able to find a lot of TSB's from mitsu for throttle body and injectors. The scanner might be like evo scan. I dunno. But it let me shut down injectors one at a time while car is running. Found out #4 was lazy. Replaced it and its been smooth since. Not saying it will be the same for you but if you can get access to the scanner its got a lot of useful dealer TSB's on it.
Old Mar 2, 2011 | 11:16 AM
  #37
Hemply's Avatar
Check your fuel pressure and pump. If it stalls when your car jolts then it could be clogging up in the tank which would stall it. Good if u can drive with scanner giving u real time feed so u know what failed when it stalls
Old Mar 2, 2011 | 12:04 PM
  #38
han's Avatar
han
might be a sign of a bad battery
Old Mar 2, 2011 | 12:44 PM
  #39
03upstatefire's Avatar
Injector's could explain this problem. Anyone with an aftermarket setup having this same issue?
Old Mar 2, 2011 | 05:05 PM
  #40
dvd_mi's Avatar
Is there an easier way to check the injectors. Without that scanner.
Old Mar 2, 2011 | 11:34 PM
  #41
Hemply's Avatar
I know that thing was 5K just for the scanner. Well I haven't tuned my evo at all so haven't tried logging with evo scan but if u can get a read on injector pulse width. Measured in milliseconds. If one has strayed from stock timing that could give u an idea but the ecm could come into play then. Its hard to say that it can be one thing without seeing the car. Sorry probably no help at all lol.
Old Mar 3, 2011 | 07:16 AM
  #42
Donkeypuncher's Avatar
Im running BlueMax 1350
Old Mar 5, 2011 | 12:29 AM
  #43
Rojo EVO's Avatar
Well, I put in a different IAC and it didn't change anything. I think I'm going to check the battery next.
Old Mar 5, 2011 | 09:14 AM
  #44
I really don't think the battery is the issue...Mine is practically brand new
Old Mar 5, 2011 | 09:29 AM
  #45
grayw's Avatar
Unless it's setup as per the instructions just changing the valve won't do any good. There is a reason why both MUT and Evoscan have the facility to set the base idle correctly. If you log the number of ICV steps at idle in Evoscan it should be no more then about 70 if the ICV is set correctly.
