fuel injector cleaner?
Spouse's Grand Prix with the little V6 had a miss and was putt putting out the exhaust. I figured on pulling the heads for a valve job but I tried the gas additive first. It fixed it.
I also have read that this stuff can be harsh on plastic parts so I wouldn't recommend doing this on a regular basis.
Also, I don't remember what brand I used. It came from Walmart.
Had a vehicle a few years ago, was still under factory warranty, and only a few years old at the time. Started running very rough, barely drivable.
Took it to the dealer and they used a fuel injector cleaner on it, and worked great. It was basically a can of stuff that they connected to the schraeder port on the injector rail and it ran on the contents of the can until the can was empty.
And when done, it was as good as new.
I always wonder about the various additives you put in your gas tank, not sure if its good for them or not. I think those additives are just marketing bs. There are plenty of additives and cleaners in the gas you get from the pump and no reason to add more.
Just my 2 cents.
Just my 2 cents.
I used BG 44k on older fords and it works great. After running it for a tank or so it really made a difference in the injector flow test results.
The old 460 fuel injected trucks were horrible for gumming up injectors and this stuff would bring them back to life.
Would this be ok to use with E85?
