Boost creep question
Old Mar 6, 2011 | 09:02 PM
noevo_nomivec's Avatar
Hello fellow evom,
I was wondering if i would get boost creep if i install a o2 housing, dp with deleled cat, and exhaust?
Is there anything I should be aware of first before i put on these mods.
Thanks,
Thomas.
Old Mar 6, 2011 | 09:05 PM
oh yeah this is far a 06 ix
Old Mar 6, 2011 | 09:06 PM
blaze-619's Avatar
I installed almost the same mods in the same day and I didn't get any boost creep.
Old Mar 6, 2011 | 09:09 PM
4RETECH's Avatar
If it is a divorced O2,maybe. You will have to see. Most here get a megan O2 and increase the diameter of the hole as to avoid boost creep.
Old Mar 6, 2011 | 09:17 PM
joseph143's Avatar
i installed a titek o2 and cobb 3'' with test pipe and didnt get it tuned for months with no noticeable side effects... other then the amazing exhaust note...
Old Mar 6, 2011 | 10:51 PM
chaotichoax's Avatar
I would suggest if you install those mods you get a tune...you'll spool your turbo more quickly and you are certainly exposing yourself to boost issues
aside from that read the evo modding for dummies thread in the stickies
you have a lot of reading to do
Old Mar 6, 2011 | 10:58 PM
SAVAGEcorpsman's Avatar
If you get the Megan 02 housing you might get it. I bought one of my friend and it's already ported, he mentioned the weakness of it is boost creep but just increase diameter. Get an Invidia 02 housing and you'll be fine.
Old Mar 7, 2011 | 05:20 AM
Thanks guys. After I get everything put on going to get a tune right whenever I can.
This what I got so far. Rsr dp with deleted cat and rsr gt2 and Megan o2 housing. Might just get a boost controlled to prevent it from boost creep.
Old Mar 7, 2011 | 01:30 PM
turbotalawd's Avatar
A boost controller will not help boost creep. The problem is that sometimes with a o2 housing, the passage is not opened enough and even when the turbo's wastegate is fully open (to lower boost), you still might not be able to run less than a certain boost level (24psi for instance).
Old Mar 7, 2011 | 04:15 PM
Ahh ic. Well I've already installed everything together so I haven't seen any boost creep so I am guessing I would need to get that tune. Which I've already planned to do.
Thanks for all the info guys.
Old Mar 7, 2011 | 04:34 PM
blaze-619's Avatar
Who's this guy?
Old Mar 7, 2011 | 06:20 PM
Originally Posted by blaze-619
Who's this guy?
Umm your friendly neighborhood SAVAGEcorpsman?
A769
Jan 19, 2012 12:02 PM
AHAZZARD
12
May 19, 2010 08:18 AM
kaonashi
26
Jan 28, 2008 03:05 PM
kaonashi
18
Jan 20, 2008 02:05 PM
negativeB
16
Dec 26, 2004 09:10 PM
