What timing light to use on the Evo
Old Mar 8, 2011 | 10:33 PM
TheBoz's Avatar
So I have a half way nice timing light however It does not register anything on the evo.
So I put the pickup on the wire that goes to plug #1, I get nothing from the timing light. If I take the wire and just put a plug in it outside of the cyl if the plug is grounded it would not register however if the plug was not grounded the timing light flashes.
I have tried different plugs.
BPR7ES
BR7ES
BR8ES
Any ideas would be helpful.
Also about 1 month ago I put an AEM EMS in my car and I was able to use the exact same timing light on my car with out issue. I also tested the timing light on a few other cars to ensure that it was working.
Old Mar 8, 2011 | 11:07 PM
nightwalker's Avatar
A timing light is not needed on the Evo. Use a scanner.
Old Mar 9, 2011 | 03:46 AM
bigben's Avatar
+1 I've never heard of anyone using a timing light on an Evo. The only way we set the timing is by using the timing "marks" on the valve cover, the one on the crank pulley, the ones on the block behind the lower timing cover, and the one on the outside of the lower timing cover.
Old Mar 9, 2011 | 09:03 AM
TheBoz's Avatar
I am on an aem ems and just put a triggerdisc in the car and as part of that i need to sync the timing.
Old Feb 9, 2018 | 06:24 PM
lopillo_evo's Avatar
Veteran: Army
Did you figure out how to use it?
Old Feb 9, 2018 | 10:40 PM
RightSaid fred's Avatar
reverse the pickup?
After 7 years.
Old Feb 14, 2018 | 09:12 PM
Teal2nnr's Avatar
You just use one of those cheap timing lights. I got my to pick up fine. I just used it to confrim base timing.
Old Feb 15, 2018 | 08:58 AM
DSMolition's Avatar
oh man 7 year bump! I stick a plug wire between the coil pack and spark plug and use an old-school light.
David Buschur
Sep 17, 2020 06:33 PM
Jared Murphy
11
May 15, 2017 08:45 PM
EVOEvolved
Jul 11, 2016 12:35 AM
commbubba19
Apr 25, 2016 10:38 AM
llDemonll
For Sale - Cars For Sale
34
Mar 23, 2016 03:08 PM
