Is the j-pipe suppose to be like this?
Old Mar 11, 2011 | 05:43 PM
mitsuclipsegsx's Avatar
My gasket from the jpipe to turbo was shot, and i took the jpipe off and it looks like it got bent, is it suppose to look like this? Should n't it be completly flat correct?
thanks
Old Mar 11, 2011 | 05:54 PM
4RETECH's Avatar
That's bent.
Old Mar 11, 2011 | 06:02 PM
evo unknown's Avatar
That looks bent. You will need to replace it with a new j pipe in order have a sealed gasket between it and the turbo to avoid leaks.
Old Mar 11, 2011 | 08:34 PM
clubEVO93's Avatar
Dang. thats weird i just took mine off and it looks the exact same. and my gasket was blowin out as well.
thanks
Old Mar 11, 2011 | 08:35 PM
clubEVO93's Avatar
What could make this bend like this? anyone know?
Old Mar 11, 2011 | 08:44 PM
where to get a new one
Old Mar 12, 2011 | 06:23 AM
clubEVO93's Avatar
No. I got my motor out of a different evo. And idk if the previous owner got into a wreck or not. But its only like 60$ on lancershop. I couldnt find the gasket for it tho
Old Mar 12, 2011 | 09:23 AM
boostless's Avatar
If the j-pipe flange is bent like that, it is definitely the cause of you gasket blow out. I've seen turbo exhaust gaskets do the same thing from a missing bolt.
Old Mar 12, 2011 | 09:38 AM
EVO_N9NE's Avatar
seems like you need a new j pipe
Old Mar 12, 2011 | 09:50 AM
ODUB's Avatar
why did you break that?
Old Mar 12, 2011 | 12:42 PM
http://www.mitsubishiparts.net/catalog/?section=1073
$46 for the jpipe and the gasket is also above.
TheMyth
Aug 3, 2017 12:11 PM
Anubis18
May 20, 2016 07:30 PM
05EV08
11
May 1, 2016 08:23 PM
evolved0414
14
Oct 1, 2009 01:47 AM
33bull
Jan 7, 2009 10:22 PM
