Im stumped. Cars running rich in open loop
Old Mar 15, 2011 | 02:07 AM
R0b's Avatar
R0b
thanks gray. Appreciate the info.
I will get some brake cleaner and try this out and report back.
just out of curiosity, in terms of nb readings. what should these be roughly at cruise and under spool and top end?
Old Mar 15, 2011 | 07:33 AM
grayw's Avatar
Narrowband will read between 0.1v and 0.9v, low voltage is lean, high voltage is rich.
Old Mar 15, 2011 | 02:05 PM
R0b's Avatar
R0b
I removed the wb sensor from the car. re-calibrated it in fresh air
then i wrapped sensor with a rag with brake cleaner on it. afr went from 21.7 down to 8.1 then remained there - waited for aboout 10 minutes then afr slowly creeped back up to 9.1.
i removed the rag, afr went back to 21.7. repeated and got exactly the same results.
this should mean that the wb gauge is in fact ok.
trying to fix my plug now to do another leak test.
Old Mar 15, 2011 | 02:58 PM
grayw's Avatar
Sensor sounds ok, where are you reading the AFR from gauge or logging software?
Old Mar 15, 2011 | 03:05 PM
R0b's Avatar
R0b
ive read from both, i normally rely on logs more however. comparing both, they seem only about 0.1-0.3 of an afr different
Old Mar 15, 2011 | 03:08 PM
grayw's Avatar
What wideband are you using?
Old Mar 15, 2011 | 03:13 PM
R0b's Avatar
R0b
sorry should have mentioned this above.
innovate lc-1 with gauge as well.
bug is welded in the downpipe - just before the flange where the cat used to be.
mods are drop in filter (cotton type but with no oil (possibly there might be a tiny bit but it doesnt feel gressy), 2.75 inch down pipe, 3 inch test pipe, hks hi power cat back, walbro, mbc 1.5bar
no recent mods.
it seemed the problem started after a batch batch of fuel although it could be just a coincidence with something else whats wrong..
Old Mar 15, 2011 | 03:25 PM
grayw's Avatar
Just one more simple thing to check, open LM programmer and make sure calibration is set to gas and not reverted to custom.
Old Mar 15, 2011 | 05:27 PM
rstchris's Avatar
On cruise and idle the WB does bounce around 14.4-14.9 right? You don't happen to have a bov that is VTA do you? Maybe leaking I would tripple check the BLT.
Old Mar 15, 2011 | 05:30 PM
R0b's Avatar
R0b
wb calibration set to gas =)
i have a evo ix meal bov - pluged back to the stock rubber intake pipe.
just waiting for the other half to get home with some parts to re-make a pressure tester as i broke my other one.
i suspect it could be leaking around the injectors which i havent tested yet
Old Mar 15, 2011 | 06:09 PM
rstchris's Avatar
Honestly, those are the exact symptoms of a boost leak. On light throttle (closed loop) it won't draw air in so fuel trims are normal. Then when you mash it the pressure starts bleeding out. Try this, take a log whilst keeping the car in CL say in 5th gear at part throttle but try to achieve boost, as much as you can and see if the fuel trims go way negative while boosting like 5psi.
Old Mar 17, 2011 | 02:39 PM
R0b's Avatar
R0b
update: found the problem.
after boost leak testing all the joins etc, there was no problems.
with a call around, i went to a friends workshop and put some red power type dye through the system and found there was a leak through the intercooler - but not on the front. it was on the back side (facing engine)
ive since upgraded and now everythings running great.
thanks everyone for your help. Ive learnt a lot through this exercise
Old Mar 17, 2011 | 02:48 PM
warstang27's Avatar
Congrats on finding the problem! good to hear everything is well again
Old Mar 21, 2011 | 06:49 PM
W2J's Avatar
W2J
"the red power type dye" how did you apply, is it safe for the motor and where can you get this to buy?
mrfred
Sep 14, 2022 07:08 PM
4b11slayer
Jul 28, 2017 10:33 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
3gEclipseTurbo
Apr 9, 2010 08:25 AM
johnnyr55
Apr 12, 2008 06:54 PM
