Is anyone else shifting from 1st to 3rd?
Old Dec 16, 2003 | 04:06 PM
the evo wins's Avatar
yeah sometimes when i redline it in first and wanna cruise at that speed i just go thru the gears and just stay at 3rd or even 4th; i do go thru the motion of shifting though i dont do the U thing
Old Dec 16, 2003 | 09:08 PM
ku7484's Avatar
well my whole purpose in doing this is........ pure laziness when its rush hour on the 5 freeway.
When i shift to 5th below 50 my car vibrates like hell
Old Dec 16, 2003 | 09:40 PM
xphillipjrx's Avatar
Shift
I like a 5th to 3rd downshift when I need to beat a yellow streetlight.
Old Dec 17, 2003 | 05:37 AM
ShapeGSX's Avatar
Don't skip gears when you upshift. It makes the synchros work harder, and will wear them out faster.
Old Dec 17, 2003 | 08:12 AM
EVOM3's Avatar
Sometimes downshifting from 5th to 1st works well.
Old Dec 17, 2003 | 08:26 AM
DrMerl's Avatar
Why, what's the difference? I myself don't jam gears when skipping gears, you still have to wait for the syncros to take in the next gear (via rev matching or time), and yes it takes longer than normal. Been doing this for years, never grind, never have problems with my trannies. Skipping gears is all about keeping the rev's low for better city mpg, nothing else.
Old Dec 17, 2003 | 08:59 AM
ShapeGSX's Avatar
There is a bigger speed difference between the input shaft and the secondary shaft in the transmission when you skip a gear. With the clutch disengaged, the input shaft won't slow down appreciably when you shift. That causes more wear than if you row.
Old Dec 17, 2003 | 01:54 PM
M3lachsilber's Avatar
choad
The best is when you shift from 3rd to the R gear which stands for "RACE"..
**** hits the fan, then..
Old Dec 17, 2003 | 02:10 PM
vegasboy301's Avatar
why not skip 1st all together?
Old Dec 17, 2003 | 02:14 PM
ShapeGSX's Avatar
You think you guys have clutch problems NOW?!
Old Dec 17, 2003 | 02:16 PM
choad
Better yet...
What the hell do you even NEED a clutch for??!
I shift WITHOUT USING IT!!!
(Try this, your gear matching abilities will improve greatly..)
Old Dec 28, 2003 | 07:19 AM
LDB's Avatar
LDB
I don't use the transmission. I just make sure the car is always pointed downhill so I can coast. So far best mpg is 312.47 but that was with a following breeze. YMMV.
