Boost leak help.
Old Mar 25, 2011 | 08:25 AM
Keoki's Avatar
Boost leak help.
I seem to have a massive boost leak coming from behind my throttle body, towards the firewall. The air is escaping from what I understand to be some sort of "Idle Air Bleed Off Flapping Device" or some crazy stuff like that.
Basically it's a silver plate with an allen key in the middle, and one Philips head screw. From What I understand this is only present on 03/04 Evo 8's
Here's a picture of the device that's leaking.
Does anyone know exactly what this does?
Old Mar 25, 2011 | 03:10 PM
BLK_EvIL's Avatar
i had same leak just pull it off and replace o-ring and put alittle rtv ultra gray selant and youll be fine
Old Mar 26, 2011 | 11:59 PM
Keoki's Avatar
So can I just put a plug in that hole and Ultra Gray the plug in place? I still dont understand what this thing does....
Old Mar 27, 2011 | 02:49 PM
mifesto's Avatar
when i rebuilt my TB with Works seals, i applied high temp RTV also even though mine didnt leak yet. relatively common point of boost leak.
Old Mar 27, 2011 | 03:05 PM
nytalonTSi's Avatar
Is it only the '03-04's throttlebodies that came with that?
Old Mar 28, 2011 | 08:34 AM
Hitmachine101's Avatar
Buy the o-ring that sits in there, im sure someone sells it, hi-temp RTV silicon it in place and put it all back together, the o-ring in there will be hard as a hocky puck when you take it out,, rubber seals get old unfortunately, replaced all the gaskets and o-rings on my gsx a year ago and no more boost leak
Old Mar 28, 2011 | 03:30 PM
Keoki's Avatar
Indeed. That seal was toast.
Well. I just RTV'ed the entire thing. around the seal, and the outside of it.
It appears I need to replace my Shaft Seal as well. BOO!
Old Apr 18, 2011 | 04:18 AM
bigben's Avatar
Hmm, guess I got something to do here soon. I would've never known about this one. Thanks for the info.
waleedmango
Evo X How Tos / Installations
30
Sep 26, 2016 06:39 PM
WikdEvo
Jun 28, 2014 07:46 AM
ILikeApples
Northwest Region
Oct 18, 2013 10:27 AM
ILikeApples
Northwest Region
Nov 17, 2012 12:20 AM
Lgkaos
Jul 3, 2011 04:38 PM
