Throttle body leak?
Old Jun 26, 2014 | 02:26 PM
WikdEvo's Avatar
Throttle body leak?
Posting this up for a friend. does anyone know what this part is and what it's for? Having some air leak out of here pretty heavily under a boost leak test.
Old Jun 26, 2014 | 02:37 PM
SilverShadow03's Avatar
Throttle body seals... They sell a replacement seal kit from several different vendors...
Here's the How Tow Replace Them Thread
And her's a link to one vendor selling them...I bought mine from MilSpec. These are from MAP.
Old Jun 26, 2014 | 02:51 PM
slowsrt4:('s Avatar
get some from MILSPEC great guys there
Old Jun 26, 2014 | 03:51 PM
blueprint's Avatar
how bad does it leak? is it even worth fixing?
Old Jun 26, 2014 | 03:52 PM
evo8426's Avatar
That is a different part of the throttle body than what is pictured above. Aby from milspec calls it "actuated idle air bleed flapper device."
Old Jun 26, 2014 | 04:02 PM
thebluesky's Avatar
https://www.evolutionm.net/forums/ev...body-leak.html
Old Jun 26, 2014 | 07:22 PM
AJCaron12's Avatar
They usually leak pretty bad. Yes it's worth fixing; it's a boost leak, and you're just putting more stress on your turbo if it's not repaired. You should always repair your boost leaks, and test the system regularly.
Old Jun 27, 2014 | 08:52 AM
moneyhun89's Avatar
Mine had the same problem. Got the o-ring and shaft seals and new tb to mani gasket all from Aby at milspec. Wasnt to hard to do and made a big diff in they way the car ran. or get a tb off a 05+ evo. mine is a 03 and i think the 04 have the same tb 05+ doesn't have the flapper.
Old Jun 28, 2014 | 07:46 AM
evo8426's Avatar
Those are not the shaft seals, is nobody else looking at what he has pictured?
WikdEvo
For Sale - Cars For Sale
May 18, 2016 08:38 AM
WikdEvo
Aug 22, 2015 07:43 PM
WikdEvo
May 31, 2015 05:34 PM
WikdEvo
May 26, 2015 09:33 AM
WikdEvo
Jul 27, 2014 12:18 PM
