Where to get the tool to install torsion bars on trunk hinges?
Old Mar 31, 2011 | 04:24 PM
cstylez52's Avatar
Hey guys I was having a problem with the trunk on the Evo 8 I purchased staying up, but after posting it on here I found out someone took off one of the torsion bars because the car use to have a wingless cf trunk on it. I have ordered the torsion bar I need but it says you need a special tool to install it. Does anyone know where I can get the tool or has anyone else ever used something else?
Old Mar 31, 2011 | 05:12 PM
chaotichoax's Avatar
use a screwdriver or pry bar
if you use a screw driver make sure it has a very think shaft as you'll be putting a lot of force on it
I've installed and uninstalled them with a good sized flat head screwdriver
I will warn you that you are put a lot of force behind the bars and you need to be careful. One slip and you'll have a torsion bar flying at you.
Old Mar 31, 2011 | 05:26 PM
cstylez52's Avatar
Sounds good, what do you do just put the flat end up against the rear deck (where the speakers are at) and use that for leverage. I have to take the LH one off because that is the one that is on there and it says you must install the RH one 1st. Thats the one I just ordered. Thanks again for the help.
Old Mar 31, 2011 | 05:30 PM
boostedwrx's Avatar
Another solution: source cf trunk and re-install leaving torsion bars out
Kidding aside, I was too lazy to reinstall the bars after putting on my cf trunk too, kinda funny hehe.
Old Mar 31, 2011 | 05:52 PM
awdordie's Avatar
I would suggest using something other than that tool as it cost 200 bucks from mitsubishiparts.net
Old Mar 31, 2011 | 06:32 PM
cstylez52's Avatar
Thats what I was thinking too. Thought maybe other members may have used something else besides the tool.
Old Nov 17, 2012 | 10:26 AM
real fast's Avatar
Anyone have a how to on this?
BbotVIII
Jun 5, 2014 04:45 AM
umopp
Mar 27, 2011 02:12 PM
05WhiteEVO8
Feb 17, 2010 02:57 PM
QwikEVO
MitsubishiParts.net - WA
Sep 22, 2009 06:41 PM
QwikEVO
Mar 17, 2009 01:43 PM
