Huge Headache!
Old May 13, 2011 | 08:15 AM
valvetap's Avatar
A boost leak check will tell alot...try that and continue
Old May 13, 2011 | 11:35 AM
reboundicon's Avatar
As others mentioned check for a boost leak and you might want to switch back to a stock Evo 9 BOV and see how that works out for you. I cant see how not having your O2 sensors would cause the car to run like that.
Old May 13, 2011 | 12:14 PM
llDemonll's Avatar
why did you start buying things before you even knew what the actual problem was..
Old May 14, 2011 | 01:48 PM
Master Evo8's Avatar
I made the mistake to replace my turbo thinking it was bad. I was very frustrated and spent alot of money replacing what I though was the trouble area. At the end it turned out my wastegate was causing my boost issues.
Old Feb 14, 2012 | 03:19 PM
adio214's Avatar
what kind of wastegate did you have and what ended up being wrong with it? but hey, at least you have nice shiney new things in your car. do you still have any other problems?
Kaezox
Jun 10, 2017 01:34 PM
axiomstyles
Sep 13, 2014 10:55 PM
jonny_502
Lancer Troubleshooting
Sep 6, 2014 06:23 PM
slammedndirty
Sep 17, 2013 11:23 PM
09_Lancer_GTS
Jan 12, 2011 02:02 PM
