Horrible Noise When Braking Hard and Accelerating. SEE VIDEO INSIDE $20 :)?
Old May 30, 2011 | 09:30 PM
CantStopSpinin's Avatar
Originally Posted by TommiM
Kind of hard to tell from the video but have you checked your swaybar endlinks? Make sure they arent loose or damaged.
Originally Posted by 05blue8
Unfortunately that video doesn't help me at all. Get a friend with a good cell phone on an empty road and give your time to get up to speed and have him record from the outside. Have you tried having someone else on the outside and see if they can hear it? Do you FEEL anything, like the car is diving? Hitting a dip? Going over a bump? Or is it just audible? Have you narrowed down everything brake related? You could do things like (if you really want to resolve it)...swap rotors/pads/calipers left to right, wheel bearings etc. The clutch issue is the interesting one...it's hard to tell from the video but I wouldn't think clutch.
ive done all that brake,bearing swapping nonsense already. sway bar and every part that can and cant be moved has been tugged, pushed , shaken, and hitten with a rubber mallet for noise. its gotta be trans or maybe even the axle teeth inside the trans could be screwed up? and as for hearing it from the outside people can hear it coming before my aftermarket (quite) exhaust
Old May 31, 2011 | 10:03 AM
GTijoejoe's Avatar
From everything mentioned, it certainly has to be something related to your transmission/drivetrain.... nothing else, IMO.
I think you have a chipped tooth or similar on your final drive or some other drive gear or spline shaft. When you decel, you get the backlash on the gears which makes the noise come on, clutch in or clutch out it doesn't matter because you're wheels are driving the gearbox. Unfortunately, the only way to tell is to take it all apart
Old May 31, 2011 | 10:06 AM
guest49582's Avatar
Originally Posted by yahu
I hate to say it, and I'm not trying to freak you out, but from what I hear in the video it sounds similar to my car after I spun a bearing. It could be the video though (it always seems to sound different in person). I don't hope I win the $20, for your sake. Best of luck.
I was going to say the same thing. Sounds like a bearing to me.
Old May 31, 2011 | 10:25 AM
L@Ncer06's Avatar
it sounds like the clutch flywheel bolts could be loose is there any slipping when you get on it also could be bearing but you said that it only happens when breaking or accelerating if it was the bearings it would make the noise at idle kinda like lifter tick im leaning more towards the clutch look threw the hole in the transmission to see if there is any metal shavings or if the clutch cover plate is scrached
Old May 31, 2011 | 10:31 AM
RA010926's Avatar
It sounds fine to me.. Turn the volume up on the music and forgot about little noises man... There's no point in going about all the little noises its just a waste of time
Old May 31, 2011 | 10:32 AM
RA010926's Avatar
bump
Old May 31, 2011 | 10:45 AM
Nasty Evolution's Avatar
Am I reading this wrong you had in a post in the first page "esspecially since my cars milage and no mods " but you list off some pretty extreme mods in just about every post after that?
Also when I'm tracking down an odd drivetrain sound I put the car on jack stands and have someone run it through the gears see if you can simulate the problem with the car up in the air with you under it. (please use proper caution when doing this of course) Car must be level and SOLID.
Old May 31, 2011 | 10:47 AM
stealthyevoviii's Avatar
What about hitting the brakes when in neutral as opposed to in gear? Any differences?
That should differentiate issues between the clutch/trans and the brakes/suspension.
Old May 31, 2011 | 10:55 AM
blackout8's Avatar
shatter
i had a spec clutch and now have a exedy twin hd. It sounds like the clutch shattering. thats normal. they will make some noise.
Old May 31, 2011 | 10:56 AM
RA010926's Avatar
Maybe some bolts are loose on engine mounts
Old May 31, 2011 | 10:57 AM
RA010926's Avatar
bump
Old May 31, 2011 | 11:02 AM
cobb_sti's Avatar
sounds like trans bearing failed. get a stethoscope and listen to your trans and see if you hear any similar sounds to what your hearing in the cab. sears has an automotive stethoscope for $12.74
Old Jun 5, 2011 | 05:19 PM
Car is actaully in a really good trans shop now. I just coudnt stand the noise anymore. they dropped the trans and should know by monday what it is. Ill keep you posted!..to anyone who cares!
thanks for everyones help btw
Old Jun 5, 2011 | 07:45 PM
DEVIL EVO IX's Avatar
did you ever figure out what the noise was?
~Sean
Old Jun 5, 2011 | 09:11 PM
reboundicon's Avatar
It is very hard to tell from the video, as it actually sounds like a squeeky belt based off what I hear. Do you know if your DP clears your ACD? It could be rubbing if you don't have a 05/06 made DP that clears ACD.
Good luck and keep us posted!
