6 bolt dsm t-belt to my evo8????
Old Apr 20, 2011 | 04:32 PM
DSMolition's Avatar
Quick question. I opened my top cam gear cover today to find my t belt worn pritty bad. Its an oem belt so im assuming its never been changed. Will a t-belt off of a 6bolt 4g63 from a 1gdsm work the same on it???. I ask because I plan on taking it out of town this weekend for boost for boobies at map and don't want to risk anything. I have 2 Greddy t-belts in good shape.
this is on a 03 gsr THANks!
Old Apr 20, 2011 | 04:35 PM
DSMolition's Avatar
map shows it being the same p/n
Old Apr 20, 2011 | 04:40 PM
rush63's Avatar
Count the number of teeth on both belts.
Old Apr 20, 2011 | 05:01 PM
javicracer's Avatar
it should be the same!!!
Old Apr 20, 2011 | 06:22 PM
DSMolition's Avatar
already got the old one off. I'm going to try the one off of one of my 1g's
Old Apr 20, 2011 | 06:48 PM
DSMolition's Avatar
hey i got my old belt off and i have not timed this engine before. Ware is the tdc mark on the oil pump and how do you line up the balance shaft to the oil pump. I never took the bs belt off.
Old Apr 20, 2011 | 07:10 PM
DSMolition's Avatar
i found the "how to" so nvm
Old Apr 21, 2011 | 09:47 AM
Blue95GST's Avatar
Belts should be the same!
Old Apr 21, 2011 | 10:17 AM
javicracer's Avatar
You are doing a t-belt job without checking the marks??! make sure all the marks line up before you start the car.
Old Apr 21, 2011 | 10:43 AM
DSMolition's Avatar
Belts were the same! not sure ware in my post I said I was not going to check the marks. Belt is on and it runs fine.
MitsuJDM
13
Dec 18, 2016 06:38 AM
bryonboals
For Sale - Miscellaneous Automotive
10
Sep 23, 2012 08:58 AM
mcm308
20
Jul 21, 2011 09:55 PM
cs82685
Nov 24, 2007 10:55 AM
