clutch pedal issue
Old Apr 20, 2011 | 04:41 PM
mrevo331's Avatar
clutch pedal issue
after i do a pull in my car, the clutch pedal like bleeds down about halfway. what causes this?
i can drive the car normal all day and it wont do it, it only does in when im WOT doing a pull. it does it about 90% of the time also. if i pull the pedal back up it stays up and will not go down again until another pull.
Old Apr 21, 2011 | 03:41 AM
yuzzimi's Avatar
Me too
I have a similar problem, does the engagement point change too?
Old Apr 21, 2011 | 09:43 AM
Blue95GST's Avatar
I know it seems basic, but check your fluid level lol, happened to a friend and no idea if it was coincidence o timing, but it fixed his problem
Old Apr 21, 2011 | 03:03 PM
mrevo331's Avatar
checked the fluid and its topped off
the engagement point seems to change a little. it also seems like when it happens, and i try to grab the next gear, its like the clutch isnt fully disengaging
Old Apr 22, 2011 | 06:06 AM
spooldursti's Avatar
Check to make sure your slave cylinder isn't leaking. It might be leaking out of the line that goes to it from the master cylinder.
Old Apr 24, 2011 | 07:31 AM
mrevo331's Avatar
checked whole system today. no leaks at all
Old Apr 24, 2011 | 07:45 AM
evo9nuuub's Avatar
you either have air in the system or a bad master cylinder,, try bleeding it first.. the fluid should be clean bc it is technically a sealed system i would say you have air in the line somewhere
bbong
Jun 11, 2017 05:25 AM
Kris86
Oct 5, 2016 10:31 AM
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
cts4g63
Jan 6, 2016 02:22 PM
Roger350
Sep 24, 2013 09:48 AM
