Typical track times?
Old Apr 27, 2011 | 05:33 PM
svt_lightning01's Avatar
So what are you guys running through the quarter and with what setup? Just kinda interested to see what works well. Never tracked mine and trying to gauge what to expect. I've got walbro pump, hks cams fidanza gears, forge mbc, evo 9 bov, drop in open filter, mishimoto radiator, 22 psi, stock turbo wastegate etc, act clutch. It's an Evo 8 MR. 6 speed. ~330 awhp. ideally I want 11's I'm sure it's not there quite yet
Old Apr 27, 2011 | 05:40 PM
SwishaSweet's Avatar
ive seen built monster power cars run 13's and ive also seen my buddys saturn with nos crank a 14 its all in the driver.
With your mods set a goal to get into the 12's consistantally then work from there. Luanching the car on the track is much differnt then on the street and also there will ussually be a ton of people watching so your going to have a little bit of nerviousness to overcome.
asininedervish's Avatar
go to https://www.evolutionm.net/forums/drag-racing-16/ for most of the drag racing discussions - good list of times for stockish cars too.
Old Apr 27, 2011 | 05:50 PM
Well I've tracked my lightning a number of times and I know these cars are a whole other ball game haha but the nervousness won't be an issue. Yeah I was hoping to be consistent 12.30's or so with good launches. Who knows we will see
Old Apr 27, 2011 | 06:03 PM
sirsol's Avatar
If you can drive well, mid 12's at about ~110-113mph. If you don't launch or are new to drag racing, low 13's at about the same MPH. Just a guestimate based on other evo's I've seen. I went 12.98 at 109 with a turbo back, LICP, buschur tune, 22 psi, and 91 octane for your reference.
Old Apr 27, 2011 | 06:23 PM
We will see! Haha I'm no self proclaimed driver by no means. I was just comparing it to my truck. It went 12.64 @ 109 weighing 4500 # which is a flying brick in the 1/4 lol. I know they are completely different set ups. Well I will just have to see what happens I'll prolly go in the next few weeks. What kind of launch should I go with? It's a six speed mr with act clutch like I said and I've heard the trannys are weak in them. I thought at my power level I wouldn't have anything to worry about with a 5k launch? But my luck is bad.
Old Apr 27, 2011 | 06:40 PM
also what rpm's are you guys shifting at down the strip? I assumed 7k but ive seen people going 8k? Is that not over revving or will they take it?
Old Apr 27, 2011 | 06:48 PM
Zerokei_XF's Avatar
Depends on the setup, if they are running upgraded springs and retainers, you can rev as high as they allow.
Old Apr 27, 2011 | 06:55 PM
hmm i was planning on just going and doing a 5k launch and perhaps a 5500 if it will allow or will hook up. Are you guys just dumping from that rpm on twin discs or slipping? I just dont wanna rip anything apart haha and ive never tracked one of these. Ive read some things up on the track launches and stuff and from what i can gather it seems like maybe a 5k or so launch dump and 7k shift would be typical?? Hopefully tranny doesn't break haha
Old Apr 27, 2011 | 06:56 PM
thats my problem with buying a used and modded car haha i know it has hks 280 cams and fidanza gears i verified that but idk about the springs and retainers idk if they are stock or not. Do people usually switch them with a cam setup?
Old Apr 27, 2011 | 07:33 PM
edogg23's Avatar
I think people usually shift at 8k if they have a tune. You should be able to get mid to low 12s. To launch you just rev and let it hit the 2 step limiter at 5.5k. Slip the clutch until it starts to engage and as soon as you start to move dump it the rest of the way.
Old Apr 27, 2011 | 07:46 PM
okay awesome man thats basically what i had taken from the write ups. People scare me with the "weak 6 speed" talk haha. At least i got the clutch i guess. Our track hooks well. How come people aren't turning more 1.6x's 60' times? Just curious and not saying that i can but i see alot of ppl turning 1.7x's and i figured that being awd the 60' would be outta this world?
Old Apr 27, 2011 | 08:51 PM
JJay's Avatar
You would get better responses in the drag section. All kinds of good info from peeps that run the 1/4 alot. Not trying to be a di€|< so please don't take it that way. Just there is alot more specific info in that section. From the title I thought you were talking about actual track times, not 1/4 times.
Old Apr 27, 2011 | 10:12 PM
sorry haha i didnt intend for it to be so detailed just looking for some references.
Old Apr 27, 2011 | 10:58 PM
chaotichoax's Avatar
you need to search before you post...you've start a lot of threads that you could have found the information for by doing some searching
closed...
drsrock
Dec 4, 2015 12:02 PM
george3
Aug 31, 2008 07:38 PM
weneversleep
Aug 13, 2008 11:19 AM
evo noob
Sep 7, 2006 01:53 PM
j8
Apr 4, 2005 10:41 AM
