Evo IX handbreak.
Old May 2, 2011 | 03:20 PM
revvin9k's Avatar
Originally Posted by 03evo8racer
Yeah man, like these guys are saying. Pull up the cup holder and adjust the nut at the bottom of the e-brake handle. If that doesn't adjust it enough, then go to the rotor and do the adjustments.
I had to do this a few weeks ago and tightening the nut was all that was needed.
How do you know how much shoe is left?
Old May 2, 2011 | 09:44 PM
barneyb's Avatar
Pull the rotor
Old May 3, 2011 | 03:56 AM
revvin9k's Avatar
Originally Posted by barneyb
Pull the rotor
I know..... it was in response to adjusting the e brake from inside the cabin.
Old May 3, 2011 | 06:00 AM
GTijoejoe's Avatar
My '92 DSM had the handbrake cable attached to lever on the caliper. The lever pushed the caliper piston out - no second brake needed. A little tug on the incar lever and the brakes were locked - a way better parking brake than what is on the Evo.
Unfortunately this is just your uneducated opinion. The Evo has fixed calipers, which is why it can not use a caliper parking brake, it doesnt' slide. This is the reason why it uses a drum brake (instead of a seperate caliper parking brake), drum brakes have higher effectiveness than caliper brakes, which is why for heavy vehicles, light trucks etc, the parking brakes are drums.
Adjusting the nut on the hand brake doesn't do anything to the shoes, it just takes out the slack in the wire system, over time the wires will stretch.
The major adjustment changes the shoe center clearance, the clearance between the brake shoe and the drum (inner rotor surface), this is needed when the shoes start to wear, it increases the shoe center clearance and you need more stroke in the system to counter, which isn't there. So you readjust the shoes to put them back at the OEM spec and your parking brake is back to being as effective as it was from factory.
Can you tell I've designed parking brake systems?
Old May 3, 2011 | 07:13 AM
barneyb's Avatar
Back out of my garage with my Evo's parking brake engaged and not notice anything until going forward as apposed to trying to back out my my garage in my DSM with the parking brake engaged and have the car hump up because only the front wheels can move, the rear wheels are locked; what further education is required to know that one braking system is superior to the other. The main purpose of a parking brake is to hold the car in place when unattended. I'm not sure the Evo parking brake is capable of doing that in all situations.
I'm very pleased that Mitsubishi used great service brakes. But the rear brakes don't do much, another design could have sufficed there - painted red with paint guaranteed to peel. So, my contention is that Mitsu gave up a better design in order to provide a matching brake in the rear. Well, I'm a function over looks guy.
Old May 3, 2011 | 07:23 AM
polish_pounder's Avatar
So did i adjust mine wrong? hahah i took the center arm rest out and adjusted the nut that held the wires for the ebrake untill they were semi tight. my ebrake does work better and grabs sooner now... ?
Old May 3, 2011 | 05:57 PM
GTijoejoe's Avatar
The drum brake has more capability, period, perhaps if you knew more about brakes you would know that. Perhaps unfortunately there is an issue with your brake. Mits cheaped out on the paint coating to save cost.
All parking brakes have to pass the same requirement by FMVSS135 regulation. 20% grade at GVWR, facing up and down hill. I'm going to bet your 4dr evo has a higher GVWR than your DSM...which means its capable of holding more torque.
By the sounds of it your DSM is FWD only??
Sorry if I've offended you, it wasen't my intentions
Old Jun 21, 2011 | 01:54 PM
dolson222's Avatar
Sorry to bring this thread back but doesn't the parking break on the Lotus Elise Brembos have a similar sytem to the piston rather style than the drum style? Any ideas on why?
Another question is surface area vs. lever arm. Does the position of the caliper style get more breaking torque efficiency than the difference in braking effieciency in surface area of the pads vs. the shoes . I could understand that on heavy vehicles that grabbing further away from the center of the hub would put more stress on all parts involved but the evo is pretty beefy for its weight so im suprised if that was part of the consideration when the lotus works differently but effectively.
I am not experienced in these matters and would love a good explaination from soemone who knows what they are talking about/ has experience.
Old Jun 21, 2011 | 02:12 PM
Raistlin's Avatar
This proper adjustment should be in the service manual (which most people never see). Adjusting the drum's shoes is the major adjustment and at the hand brake lever there is another adjustment nut for the wires, this is the minor adjustment. Only adjust the major of the minor is already at its limit. (don't torque the hand brake adjustment nut too much or you'll brake it.)
+1
This is exactly how it is to be done.
Service manual is full of win.
Old Jun 21, 2011 | 07:51 PM
DEVIL EVO IX's Avatar
great info might to to do that
~Sean
Old Jun 22, 2011 | 10:12 AM
revvin9k's Avatar
I have NEVER touched the adjustment of my e brake from inside the cabin.
While pulling the rear wheels is a major pITA compared from doing it in the cabin...its the only way to go.
Old Jun 22, 2011 | 02:38 PM
FJF's Avatar
FJF
Back out of my garage with my Evo's parking brake engaged and not notice anything until going forward ...
<blush> I've had a similar experience.
Old Jun 23, 2011 | 07:03 AM
GTijoejoe's Avatar
"the only way to go" is poor advice, I'm gald it worked for you though
You should know there is a reason for the major and minor adjustments.
While the parking brake wire stretches over time by a few mm its needed for the minor in cabin adjustment. Jumping directly to the major star wheel on the parking brake assy is not wise. As the only reason to adjust this is because the shoes are warn and you have to readjust the shoe center clearance to the drum back to the factory specs.
A word of caution, if you over adjust this (ie, your shoes arn't warn and you jump righ to the major adjustment), you can have brake drag (over heat the drum) and self energization of the parking brake assy = it locks by its self... Just FYI.
Old Jun 23, 2011 | 09:56 AM
revvin9k's Avatar
Brakes are not a science, and while I appreciate the sound advice, I knew my shoes needed replacement as I use it to slow down if I am traveling above the speed limit and see authorities as not to trigger my brake lamps.
What I stated now as I have before, is that it is ALWAYS wise to pull your wheels REGARDLESS to at least see what type of shoe material you are working with prior to making ANY adjustments.
Old Feb 25, 2012 | 12:47 PM
03BoostedVIII's Avatar
I will be adjusting mine today, I will attatch pictures of both area's if I need to go beyond at the handle.
