A little problem encountered after clutch started to slip
Old May 5, 2011 | 11:05 PM
ProjectDrknss's Avatar
Hey guys, I'm in a bit of a jam. Recently, my clutch started slipping. After realizing that my clutch was slipping, I drove it around for three days to and from work which is about 4 miles one way. On the third day, I drove it back to Stockton where my dad would help me change the clutch. The next day we messed a bit with the clutch line and I drove it around the block and parked again. Upon trying to start it up this time, nothing happens. No clicks, no turn over. All the electrical turns on and works properly. Could the clutch be the reason why it won't start? Any suggestions, feed back would be appreciate. As of right now, it's sitting in the garage on jacks awaiting the clutch. Thanks!
Old May 5, 2011 | 11:23 PM
LancerEVA06's Avatar
Try disconnecting the switch at the clutch pedal.
Old May 6, 2011 | 11:11 AM
acidtonic's Avatar
This is probably it. If it starts with the bottom clutch switch unplugged, you probably bumped it and the pedal no longer presses the switch properly.
Let us know.
Old May 6, 2011 | 05:46 PM
Jerry321's Avatar
yup try disconnecting the switch....you probably wore to clutch all the way down its too thin to engage....
Old May 6, 2011 | 07:33 PM
barneyb's Avatar
That or you knocked the little wire off the starter.
Old May 7, 2011 | 04:38 AM
My03evo's Avatar
Let us know.
Actually I believe that the switch is "pushed" all the time and it gets "released" when you push the clutch
Not like it matters, just sayin
Old May 7, 2011 | 01:40 PM
Thanks a bunch guys. After my dad and I put the new clutch in and everything, I'll try this out. I'll let you guys know. Thanks again!
sUp3rSiMpLiCiTy
Oct 14, 2015 01:17 PM
Insanity Evo
May 31, 2011 05:11 PM
str8kor
Oct 30, 2009 07:52 AM
Tek3Evo
Aug 14, 2008 01:25 PM
jeemybo
Lancer Aftermarket Forced Induction Tech
10
Aug 18, 2006 03:49 AM
