found a loose wire, what is it?
Old May 11, 2011 | 04:02 PM
HN7's Avatar
HN7
I found this wire not hooked up to anything when I pop my handbrake console off. What does it do and is it supposed to be connected?
Old May 11, 2011 | 04:17 PM
awdordie's Avatar
Obviously its a ground since it looks to be going to the bolt. Did the car have a system or aftermarket radio or anything aalong thos lines?
Old May 14, 2011 | 06:40 AM
z32cctx's Avatar
It is a ground and is not factory. If I had to guess it would have been for a gauge with a light or maybe a aftermarket radio. Since it was cut on the other end what ever it was connected to has been removed from the car now.
Old May 14, 2011 | 07:17 AM
mrboost05's Avatar
could have been for anything radio turbo timer gauges just take it out if it dosent run to anything.
Old May 14, 2011 | 09:27 AM
HN7's Avatar
HN7
Thanks for the help guys. It is gone.
Old May 14, 2011 | 10:23 AM
z32cctx's Avatar
No Problem Its the wires that actually go to something that should worry you. Sucks when you find a wire that's cut and snakes behind your dash. =-\
I had that problem with a 300zx TT I had. Turns out it was for a aftermarket dash cluster glow kit. Was a pain in the *** to remove the wires they left and fix the mess they made in the wiring harness.
Old May 14, 2011 | 11:26 AM
Arctic02z's Avatar
i dont understand why people can take wires out completely when uninstalling things, instead of leaving loose stuff like this..
