Prosport oil pressure sender
Old May 12, 2011 | 03:26 AM
sleepy_rps13's Avatar
Is there anyone that's running the Prosport performance series oil pressure gauge and running into problems with the sender? This is the third gauge and second sender that I've gone through in the past year. And I had just gotten a brand new gauge and sender a few months back. The main problem is that the sender unit seems to be going bad. The car could be off but the pressure will read 10psi. When I go and tap on the sender a few times, it will zero out and read fine. If I don't go and tap on the sender unit, the gauge will read higher than what it really is. Is this a common problem with these gauges? Thanks.
Old May 12, 2011 | 05:15 AM
Bobster22388's Avatar
Are you sure you have a good ground for your sensor? I am using AMS's oil pressure sending unit adapter line and have not had any problems for over a year now.
Old May 12, 2011 | 05:19 AM
4bangn's Avatar
hmmm, yea mine crapped out over 6 months ago now, just havent had time to mess with it it yet, yea the gauge just sits at zero now, with car on or off, just stopped working one day, not sure if its a performance series but its definitely a prosport gauge
Old May 12, 2011 | 01:02 PM
Definitely not a grounding issue. Checked and cleaned all the grounds. All my other gauges are working properly, just this one ands its components that keeps crapping out after a while. The first one worked fine for almost half a year while this one worked correctly for the first 3 or so months. Then it started acting funny... Is it just the quality of these gauges and components? Should I swap out to something else because I don't want to have to buy a new gauge every few months...
superkizuna
Jan 9, 2017 06:32 PM
Lombardi23
Apr 30, 2016 01:03 PM
EmGee
Jun 26, 2015 10:53 PM
fjm9898
Dec 24, 2013 06:13 PM
the1tonton
Jan 30, 2013 06:56 AM
