Driver's side wheel slighty sticks out towards the bottom, help.
Old Jun 7, 2011 | 07:21 PM
EVO8STI's Avatar
maybe its not your wheel at all. maybe its your bumper? or something like that
Old Jun 7, 2011 | 08:19 PM
chaotichoax's Avatar
take it to a shop...did you talk to the alignment guy and tell him the situation?
the alignment isn't the best but it's not terrible...certainly isn't explaining the wheel issue
Old Jun 7, 2011 | 08:34 PM
evo_skillz's Avatar
I guess when I get paid I'll take it to another shop and see if they can see what's happening. this is really frustrating, wish i knew what the problem was. could it be the body that's slightly crooked our something of that sort.
Old Jun 7, 2011 | 09:31 PM
06MREvo's Avatar
Dude your wheel is barely different...I wouldn't even worry about it...Looking at your alignment sheet though, it needs some work but that all depends what you do with the car. Front camber -1.5* to -2.0* and 0* toe...Rear camber -1* to -1.5* and close to 0* toe or a little bit negative...
Old Jun 8, 2011 | 01:11 PM
evo_skillz's Avatar
thanks to all who responded, 'preciate it. I'm not gonna worry about it anymore as it's probably nothing. I'm gonna start savin' up for a new suspension setup anyways, might go with bilstein hd and gtworx springs.
Old Jul 13, 2011 | 10:41 AM
evo_skillz's Avatar
What would cause more negative camber? blown strut.....?
Old Jul 13, 2011 | 07:38 PM
TommiM's Avatar
Ya, because the car will squat down a bit more giving the tire greater negative camber. That might also explain why you hear compression noises in your rear struts. They could be blown.... BUT... Any alingment shop worth its weight will do a underbody/suspension/tire inspection before performing an alignment. You cant properly align a vehicle that has bad bushings or blown struts.
I recommend getting a jack, jack stands and a flashlight and getting under your vehicle and see if anything looks wrong under there.
Old Jul 13, 2011 | 08:14 PM
evo_skillz's Avatar
thanks man 'preicate it, I'm gonna make an appointment this week with alignment factory, heard good things about 'em, just have to wait and see. Hopefully everthing turns out ok.
beetle_orange
Jul 5, 2012 07:39 PM
evo_skillz
Jul 25, 2011 05:51 PM
3gEclipseTurbo
Dec 5, 2010 10:45 AM
brenner
15
Nov 8, 2010 07:10 PM
IS2000
Jul 19, 2004 11:08 PM
