wastegate setting
Old Jun 6, 2011 | 09:30 PM
Boostedx11's Avatar
wastegate setting
After installing a stock wastegate back on an evo 9 turbo i feel as though I had to stretch it further than normal to hook it on the hot side. Is this normal? it seems that this would cause the wastegate to open early. I can get pics of the wastegate if necessary.
Old Jun 7, 2011 | 05:50 AM
Nashou66's Avatar
Make sure the arm is in the right position for best fitment . It will turn in the can so align it that way, if it still seems like you have too much preload then turn the buckle at the end of the arm to the amount of preload you need. there is a video on forced performance site on how it is done.
Also if its harder to put on it wont open as soon, not too soon as you mentioned.
Athanasios
Old Jun 7, 2011 | 07:51 AM
05blue8's Avatar
Correct, you have it preloaded to hold more boost longer. At stock it tapers very quickly, with preload it holds a couple psi into redline. If you're tuned it was probably set that way intentionally.
Old Jun 7, 2011 | 01:43 PM
Boostedx11's Avatar
sounds good. ill check out that video... It was from a 9, but im not sure what the setup was so ill check out the settings and then leave it that way until i tune it on this car.
7thGearRacing
Sep 15, 2015 01:30 PM
eb66
Apr 28, 2010 07:01 AM
5LEEPERISAH23I
Apr 15, 2010 07:47 AM
fr34k
Sep 2, 2005 10:19 AM
superman105
18
Aug 24, 2005 03:58 PM
