267whp on Dynapack
Old Dec 26, 2003 | 06:38 PM
DynoKing's Avatar
In Timeout
I got this 100% stock
Old Dec 26, 2003 | 09:17 PM
zstryder's Avatar
Originally posted by MrBonus
Just an FYI... I ran the Buschur Turboback (No Cat), AEM Short Ram Intake, and an SAFC II that got dialed in at Agile and made 279.4. I had no boost control and was seeing stock boost levels.
I was also on the exact same dyno with probably nearly identical weather conditions.
Yank that crappy stock cat!
I would, but we have emissions tests here in VA and cops are so **** that they'll pull over cars for being smelly. Somehow not worth the risk.
Nice numbers! What are your AFR's?
By comparing our HP graphs, your HP seems to peak a little later than mine. You're peaking at 6500 where I seem to be peaking at like 5800. I don't think they really tried leaning me out beyond 5500. I wonder if I just add a -1 or -2% for all the top end stuff I'd get a little more oomph?
Old Dec 26, 2003 | 09:26 PM
zstryder's Avatar
These are my settings:
3800 -3%
4200 -2%
4600 -1%
5400 -10%
6200 -12
6800 -9%
7000 -11%
7600 -11%
Hm, now I just noticed.. why the big gap between 5400 and 6200?
My AFR's get really rich from 5500 onward, I wonder if maybe I could have extracted more power?
EDIT:
I am thinking I will just manually drop in another -1 or -2% from 5500+ rpms. How many points would -1% drop on the AFR?
Would it be unsafe to run 11.5 AFR all the way to redline? It should be okay, right?
Old Dec 27, 2003 | 12:11 AM
bpclements's Avatar
Depends on what kind of fuel you get. I don't think it would be a problem on 93 octane. I would try to stick around 11.0 up in the high end. That's just me and I only get 91 here.
Old Dec 27, 2003 | 07:12 AM
MrBonus's Avatar
My AFRs were in the 11.5 range, if I remember correctly.
I just moved up from Ballston so I know what you mean. You've got to be really careful around the cops there. They usually left me alone because I kept my out of state tags.
Oh, and I don't have to do emissions in Delaware until '08. Shhhh... Don't tell the man.
Old Dec 27, 2003 | 01:02 PM
zstryder's Avatar
Would you happen to have a scan of your AFR's? What are your SAFC settings?
