Motor noise only at certain RPM
Old Jul 3, 2011 | 02:20 PM
Joshm3357's Avatar
amsoil 10w-40
Old Jul 7, 2011 | 07:39 AM
sr20det91's Avatar
I'd bet anything your balance shaft is 180 deg out of phase. Classic symptoms..
Old Jul 8, 2011 | 08:51 PM
mmmmbst's Avatar
Veteran: Air Force
Originally Posted by mitsuorder
Your balance shaft gear spun 180* out. You need to take it back to the person/shop who did the work. They are going to have to take the timing belt back off and rotate the balance shaft gear to get it back in phase.
mitsuorder
This is your problem, I'm 100% sure. Happened to me when I bought my car. Have it retimed and get some money back for their mistake. Theres a port on the front side of the block they were supposed to remove and check the position of the front balance shaft before setting the timing on the oil pump. good luck!
Old Jul 9, 2011 | 03:27 AM
Joshm3357's Avatar
I have been insanely busy and still havent looked into this. The car is not my daily so its been sitting in the garage.
It did this prior to just getting the timing belt done though. CBRD did the timing belt and 60k.
smevox
Jan 14, 2019 07:13 AM
zxac
Lancer Troubleshooting
15
Sep 29, 2015 01:04 PM
Sanzie99
Jan 16, 2012 05:27 PM
ChaoticEvo
Nov 17, 2010 05:42 PM
adcgn45
Dec 3, 2009 11:02 AM
