Mild build on Evo 9, Will I need injectors?
Old Jul 5, 2011 | 06:26 PM
MatcoBill's Avatar
Originally Posted by evo8426
You might as well do the valve springs, you'll kick yourself in the *** later on if you don't It's not just upping the rev limit that matters when running the higher lift cams, boost pressure also plays a role in it. You should always mod for reliability. It will save future headaches. With the injectors it is best to get more injector than you think you need so you never have to replace them in the future.
I'd def do springs with cams
Old Jul 5, 2011 | 10:12 PM
IbeBOOSTIN's Avatar
[quote=evo8426;9439161]You should always mod for reliability.[quote]
this should be at all times in the back of your mind
and as far as considering the bigger go with 1000 to 1200
cause if you think your done modding think again lol
cause if your like me n others when a certain power goal is met
its the nature of the beast to want more lol
Old Jul 5, 2011 | 11:06 PM
pacent's Avatar
I have to do more research, but I haven't seen or heard of anyone running into valve float revving to stock RPMs on M2 cams. With that being said, I may just get GSC Beehives anyways just to get all my bases covered. Thanks for the input everyone.
Old Jul 6, 2011 | 06:35 AM
Broham's Avatar
good choice, but its not just valve float to worry about. Beehives are much better, also if you ever go big turbo, you'll rev higher to get the power and youll need good springs. gsc or kiggly will work fine
Old Jul 10, 2011 | 11:56 AM
Tatmonster45's Avatar
Definitely get injectors. Preferably 1k
Old Jul 10, 2011 | 04:28 PM
RockmanX's Avatar
as mention above im in the crowd of getting injectors to small as i thought i would never be going e85 then long behold they open up a couple of e85 stations down the road from me. so then i ended up selling my 1000cc injectors that i had the shop install car was never cranked up with the 1000cc but they were installed and they were moving on to buttoning up my motor when i changed on them to 1450cc so luckly JMS was cool about it and did not charge me extra to swap them out. You need to get 1450cc injectors that will cover everything and as stated above you need to upgrade your springs as well no excuses
Old Jul 11, 2011 | 08:54 PM
SikofFalln's Avatar
Might as well get the injectors. May I suggest a cone filter instead of a drop in? Also, why do you not want to run e85? I hear once you go corn you won't want to switch back to pump
I have heard talk that the government will be discontinuing the subsidies that they currently have on Ethanol, not sure how that would effect people running E85, but I can't imagine it would be good.
Old Jul 13, 2011 | 08:46 PM
clubEVO93's Avatar
Bro def look into a clutch. I have on my car the exact samething as you but besides the cams. and my cars clutch is slipping at 342whp and 319lbtq. My car isnt beat on. I have 48k on it.
Old Jul 13, 2011 | 08:56 PM
EV0L-IX-MR's Avatar
+1 on a clutch I got 381whp and 363 wtq with 21k on the car and it's just about done. Waiting for new one to arrive. Besides the MR transmission isn't exactly the greatest.
Old Jul 13, 2011 | 08:59 PM
evo8426's Avatar
How is it not a good transmission? There are many people with plenty of power that still run it. There are also many people with close to 150k miles on the MR transmission. Only thing I have heard causing it to break is real track racing, not from street duty.
You might need to learn to drive manual better if you have killed your clutch in 21k miles with that low of power. I have 48k on my stock clutch with very similar power.
clubEvo93, your car isn't beat on? I don't see how not if the clutch is slipping already.
Old Jul 13, 2011 | 09:00 PM
clubEVO93's Avatar
yes it isnt. What mods are on your car EVOL?^1
Old Jul 13, 2011 | 10:14 PM
pacent's Avatar
I have a budget in place for a clutch, but not planning on replacing it until the stock one starts slipping.
The car is currently at APM tonight to have the Megan o2 housing and AMS TBE installed.
Pretty much everything else on my list has been purchased as well:
GSC Beehives
Cossie M2 cams
MAP Head Studs
ETS FMIC
ETS Intake
ETS LICP
Walbro Fuel Pump
850cc Injectors
I'm sending the injectors out to be cleaned tomorrow, and then the rest of the mods will probably go in within a few weeks after the injectors come back.
Old Jul 14, 2011 | 07:41 PM
EV0L-IX-MR's Avatar
I track the car hence why the clutch is gone. As far as mods go I got HKS 3" TBE HKS intake HKS 272 cams HKS cam gears cosworth springs and studs. HKS EBC 6 AMS FMIC with upper and lower piping, and a HKS F con V pro. As well as a FP Green sitting in my garage no time to instal yet but it's on pump gas.
Old Jul 14, 2011 | 07:45 PM
EV0L-IX-MR's Avatar
My manual driving skills are pretty good but I track the car at least twice a week. Pretty much for all 21k
Old Jul 17, 2011 | 12:31 AM
mikeywick821's Avatar
kind of off topic question, but when upgrading to the FP green, is anything needed to support the bigger turbo? or will upgraded injectors and cams basically do the job to support the turbo?
