major problem or simple fix
Old Jul 15, 2011 | 09:56 PM
usnevo8's Avatar
Okay, so today i go to replace my exhaust manifold gasket today and get it on without major problems at first. I get everything put back together and then go to screw in my banjo bolt for the oil feed line that bolts into the head and it never tightens. Should i try to heli-coil it before i actually pitch out the money and buy a new head or whats some suggestions?
Old Jul 16, 2011 | 02:03 PM
black_beauty's Avatar
Y did you remove the feed line? Its def not necessary, i just did an exhaust manifold gasket last week.
Old Jul 16, 2011 | 02:30 PM
NOMIEZVR4's Avatar
I doubt helix coil will work on the head for the feed line. If you truly can not tighten the bolt, then i would suggest getting a ss oil line.
Old Jul 16, 2011 | 03:49 PM
usnevo8's Avatar
I had to remove it because I needed to slide out the Turbo and then it wouldn't reach when I tried putting it back on so I loosened it from the Turbo and then tightened it all back up only to find out it got cross threaded from the beginning.. im switching to an fp black soon so ill just run the other oil feed line setup
Old Jul 16, 2011 | 09:39 PM
bluedevil06's Avatar
i would suggest a heli-coil of the same threads since it is cheaper, the heli-coil i think can hold up to about 20 ft lbs.
Old Jul 17, 2011 | 06:48 AM
mithrandir7533's Avatar
I had this happen from taking my turbo out too many times. I went with the FP oil feed kit that taps into the oil filter housing. It gets rid of that oil feed line altogether and plugs the head. It will make installation easier as well.
Old Jul 17, 2011 | 07:23 AM
evo8426's Avatar
Doesn't FP supply a short bolt to go in the hole? The thread is still stripped and the supplied bolt won't fit tightly. Your idea was the first thing I thought of except I still don't think it will work.
Old Jul 18, 2011 | 07:07 PM
It's longer than the banjo bolt. Mine was stripped and the FP bolt went in.
Old Jul 18, 2011 | 07:12 PM
dscevo8's Avatar
English Racing heli-coiled both mine and a buddies oil feed line hole after we stripped it. It can be done...
Old Jul 19, 2011 | 06:08 PM
Mikey@Spec-Ops's Avatar
Correct, the FP bolt is longer so should work Will. Oil filter housing feed kit
Let me know and I'll order one for you brother.
Mikey
Old Jul 19, 2011 | 06:13 PM
WHTEVO's Avatar
I used Heli coil on one of my 1G DSM's and it worked great. So i would go that route or get the FP bolt.
Aaron
Old Jul 23, 2011 | 01:22 AM
mcjallen's Avatar
They definitely did! haha Not too expensive either and it works.
