BOV Flutter after Perrin Intake Install
Old Jul 17, 2011 | 05:48 PM
MatcoBill's Avatar
I just took out my 8 for a test drive after installing a Perrin intake and as expected the BOV is louder but what is unexpected is that it doesnt sound crisp, it has a flutter sound to it each time i let off the accelerator....The BOV on my car is a WORKS diverter valve.....any thoughts
Old Jul 17, 2011 | 05:56 PM
Pal215's Avatar
Check to see if you reinstalled your bov the exact way you removed it initially. It could also be that it always fluttered, but now since its a much more open intake, you can hear it fluttering. When i installed my perrin intake, the characteristics of the bov remained the same as before.
Old Jul 17, 2011 | 06:06 PM
MatcoBill's Avatar
i could barely hear it with the stock box
Old Jul 17, 2011 | 07:27 PM
bigben's Avatar
That's why you hear it so easily now, because you aren't using the box, just an open filter. This is normal.
Old Jul 18, 2011 | 05:37 AM
MatcoBill's Avatar
I understand that I am going to hear it but should it be a crisp sound, like opening a can of soda? Mine sounds like a soda opening with a fluttering sound after
Old Jul 18, 2011 | 05:41 AM
wht95scort's Avatar
If the BOV is adjustable you need to adjust it untill it stops. The flutter you are hearing is turbo surge.
Skott2k's Avatar
I use Synapse bov and its the exact same thing. I recently had my 60k done and asked specifically for them to check on that while doing a test drive and from what i was told is that its normal. I know what you mean it doesnt feel/sound right but i cant find anyone to diagnose it with anything other than normal.
Old Jul 18, 2011 | 05:52 AM
marcusE's Avatar
search turbo flutter, bov flutter, compressor surge. Bound to find some helpful information.
Old Jul 18, 2011 | 10:34 AM
rsboy's Avatar
check if you installed the bov the correct way.
here's a pic for reference..
Old Jul 18, 2011 | 10:36 AM
ViNZx_xD's Avatar
stock wont be alot louder i guess.
Old Jul 18, 2011 | 10:38 AM
Paintballguy's Avatar
sounds like an issue with your bov.
Old Jul 18, 2011 | 10:54 AM
MatcoBill's Avatar
now im wondering if its on backwards after looking at that pic
Old Jul 18, 2011 | 10:58 AM
gsrboi80's Avatar
Bottom port goes to the UICP side port to the Intake
Old Jul 18, 2011 | 11:24 AM
Boostd4's Avatar
The sound won't be a "crisp" release sound. What you're hearing is normal.
Old Jul 18, 2011 | 01:09 PM
deadmeat's Avatar
Mine sounds like my car is sneezing.
When I'm on the throttle there's the loud whistle of the turbo spooling + the intake breathing in a ton of air then when I let off there's an audible "chooo"
Check this video to see what I mean:
http://www.youtube.com/watch?v=5YvRcS8UD-Q
Before my cams went in I would only get flutter if I was going up a hill in 5th gear at really low boost levels. Now I get it in 3rd-5th pretty easily but still only at partial throttle/2-3 pounds of boost. No flutter at all during WOT pulls though, never have experienced that.
