Stock steering wheel getting rough spots? Maybe this will help.
I tried this on my stock steering wheel today and it looks nice and almost new looking (at least for now).
The problem was I have noticed a rough spot on the top of the wheel from the previous owner and it has gotten a bit worse since I have had the car. This morning though I took the car to get it inspected and heading home it seemed like I was holding sand paper at times. This could have also been due to the fact that I had been at work all night and was tired as well.
Regardless here is how I fixed my problem.
I had read before that cardboard can be used as a light form of sand paper. Not being one to want to use real sand paper on my steering wheel I figured I would give this a try.
I took a box and cut a small piece off of it and used it as I would dry sand paper. Within less than two minutes the rough dull spot was shiny and smooth again. I know this is not a completely permanent fix such as getting the wheel redone or buying a new one but it is a fix. I will update from time to time how well this is holding up.
As for now though I have the feel of a new steering wheel.
Thanks got the idea from this thread.
https://www.evolutionm.net/forums/ev...ul-gauges.html
Took a bit of work and the gauge will only read to 30 psi (which is more than I will ever use), but I think it works well with my plans for as stock looking as possbile.
chaotichoax
Aug 5, 2017 06:28 PM
bandwagon
15
Apr 11, 2007 10:12 AM
