new fuel rail necessary with new injectors??
Old Aug 11, 2011 | 07:59 PM
khasal's Avatar
Do i need to upgrade my fuel rail if I am upgrading my injectors??
Can I just buy larger injectors and throw them in without a RE-tune?
Old Aug 11, 2011 | 08:48 PM
No need for a high flow fuel rail based on a level 1 E85 mod
IMO, the HF rail is only needed when at the high end of the power mods
Yes, You must re-tune after installing any exterior engine mods.
Old Aug 12, 2011 | 05:15 AM
s.lamoureux's Avatar
im running 1680cc injectors and double pumper on stock rail
Old Aug 12, 2011 | 05:43 AM
That just about sums it up Wonder if the OP has upgraded the fuel pump
Old Aug 12, 2011 | 12:44 PM
black_beauty's Avatar
Fuel pump will be a def improvement, will def need a retune...
Old Aug 13, 2011 | 09:03 AM
khasal's Avatar
Yes. When I bought the car, it already had a fuel pump upgrade. Walbro 255
Thanks for the information.
I want to go with an e85 setup on 1050cc injectors or better.
Old Aug 13, 2011 | 09:05 AM
khasal's Avatar
why wouldn't you upgrade the stock rail? Aren't you running with a lot of power?
i'd go bigger on the injectors so you just have to buy once, the price difference between sizes isn't that much.
Old Aug 13, 2011 | 09:57 AM
Ian0611's Avatar
Sorry to thread jack, but at what point does it become neccesary to upgrade the fuel rail? Is there a certain HP level or boost level? Also, is there a big difference between the rails that are out there? I tried to search but didn't find a whole lot of reviews on fuel rails.
Old Aug 13, 2011 | 07:46 PM
khasal's Avatar
I am not familiar with the tuning side of things, so I dont know how big I can go without being too big! For example, I can shell out the extra 50 bucks and buy the 1450cc injectors. Will that require a double pump set up?
I am not sure how one figures these things out.
Old Aug 13, 2011 | 07:59 PM
vmrevo9's Avatar
Veteran: Air Force
1450cc are fine on a single walbro 255 on stock turbo. heck that will be my choice of injector whenever i upgrade from the 1000cc and im on a BBK Full. i would definitely go with the 1450's at least they will be good if you decide to go with a larger turbo. also depends on the turbo
Old Aug 13, 2011 | 08:00 PM
sr20detisbetter's Avatar
No def not
Old Aug 13, 2011 | 08:06 PM
vmrevo9's Avatar
Veteran: Air Force
stock rails are pretty stout.
Old Aug 13, 2011 | 08:08 PM
Yeah I've seen plenty of evos around here running huge injectors on stock rail
Old Aug 13, 2011 | 08:11 PM
it just doesn't need it right now, i'll be at 450+whp very soon and still on stock rail. The stock one works pretty damn well, just doesn't look as purdy.
