turbo coolant line leak
Old Aug 15, 2011 | 11:39 AM
BoosTyEVO's Avatar
its a evo 8 with a fp black turbo , noticed one of my coolant lines was leaking and I'm not sure to order evo 8 coolant lines or evo 9 or if they are the same size , also could i simply just buy some standard coolant hose from like napa ? is the diameter the same I noticed the hoses seem to be molded so was curious if that would matter appreciate all the input
Old Aug 15, 2011 | 12:56 PM
geevolution's Avatar
You would need the Evo 9 coolant line if I'm not mistaken. You can get it from your local dealer, from FP, or mitsubishiparts.net
Old Aug 15, 2011 | 01:02 PM
YogSaahoth's Avatar
Veteran: Army
Leaking from where exactly? Coolant lines are on the front and rear of the turbo. Is the leak from where the metal line mates with the turbo center section via banjo bolt, or from the rubber lines that are clamped to engine feed and return lines? You may not need to replace the actual lines, but the hardware instead (bolts, washers). But if you do need new lines you would have to order evo 9 lines since its an evo 9 based turbo.
Old Aug 15, 2011 | 01:46 PM
BoosTyEVO's Avatar
here is a pic of the location
http://i36.photobucket.com/albums/e3...leaky-hose.jpg
sorry i could do a close up i just happen to take this pic before i noticed the leak could take a closer up pic if needed
Old Aug 15, 2011 | 01:49 PM
BoosTyEVO's Avatar
i called the dealership and he said he wasn't sure and also there was 2 different parts i think because of the years of the evo 9 not sure wich year , to go with the car is 2003 evo 8 , but turbo is fp black
Old Aug 15, 2011 | 01:57 PM
sho669's Avatar
Is it just the clamp or the hose?
Running the NAPA hose would probably save you some cash and isn't going to hurt anything as long as you route it correctly.
EVO IX was in the states for one year, so unless there was a build date split I don't see how there would be two different parts for it, unless you're talking about VIII and IX hose numbers.
Anyways as said before you need the IX hoses now since you have a IX turbo.
Old Aug 15, 2011 | 02:11 PM
BoosTyEVO's Avatar
its gotta be the hose cause it looks like its worn its like expanded looking guess i'll probly just get the 9 hoses thanks for the help appreciate it guys
Old Aug 15, 2011 | 02:15 PM
Kracka's Avatar
I found a hose that fit with the molded bend and everything at my local auto parts store. It wasn't any cheaper than the dealership, but it saved me a trip at least. I just brought in the stock hose and went through their rack of hoses until I found one the same size/shape, just had to trim the legs shorter.
Old Aug 15, 2011 | 03:30 PM
Spec-Ops1's Avatar
I just used some -6AN push lock line with a 3/8" inner diameter...
Old Aug 15, 2011 | 09:07 PM
thegoodservant's Avatar
I replaced that same hose a couple weeks ago with a $3 napa silicone hose works great.
Old Aug 16, 2011 | 05:45 PM
BoosTyEVO's Avatar
fixed
once again thanks for the input I decided to go with some silicone coolant hose 3/8"
worked perfectly easy fix here is a pic
http://i36.photobucket.com/albums/e3...t/IMG_2483.jpg
Old Mar 2, 2013 | 03:17 PM
bnr34rb26dett's Avatar
this just happned to me now. im gonna go buy myself a 3/8 silicone hose now
thanks!
Old Apr 19, 2013 | 06:31 PM
marcusE's Avatar
I'm getting some drips from the rubber part just after the clamp on mine too now... guess the rubber expanded or something
timv
16
Jun 6, 2021 03:11 PM
jheff
Jun 11, 2020 01:23 PM
grim~
Jan 22, 2016 06:05 PM
aggieEVO
Feb 12, 2014 01:34 PM
naudlee
Aug 15, 2009 12:10 PM
