hard wiring dw300
Old Aug 16, 2011 | 11:38 PM
utripin's Avatar
hard wiring dw300
Going to re-hard wire my DW 300 FUEL PUMP. my question is which pin should I use from the ecu for a turn on signal. Pin 22...or pin 39. The EVO pump uses three relays with a resistor. At low demand the pump gets 10 volts, jumps up to 13 volts on high demands. Wiring diagram says pin #22 is the fuel pump relay, pin#39 says It's the relay for high demand. Which one should I use for a signal to my new relay? Has anyone done this before? My guess is pin #39.
Old Sep 27, 2011 | 12:46 PM
feautoevo's Avatar
Revive this!! lol I've been searching for hours, is there a simple way to utilize the factory ecu, Hi/Lo pump control for the hard wire of the pump (or pumps) as I'm looking to hard wire the TWO DW 301's...
Thanks guys!!
Old Sep 27, 2011 | 12:56 PM
The heads in this thread should know the answer
https://www.evolutionm.net/forums/ev...rformance.html
Alchem1st
Mar 15, 2022 08:47 AM
ahmedshaikhani
Aug 24, 2021 10:24 PM
FL3JM
Feb 26, 2017 10:30 AM
onefast2gdsm
Dec 14, 2016 11:42 AM
hotstix
19
Aug 16, 2011 09:51 PM
