evo 8 sunroof question
Old Aug 26, 2011 | 07:14 PM
Ian0611's Avatar
Originally Posted by luvboost
I can hear the sunroof motor working just fine. My sunroof however just doesn't move at all but I can slide it back and forth with my hands. It had to have just fallen off the tracks however that happens. I'm gonna order what ever it needs before I attempt to fix it.
If I remember correctly, the glass is held only held on by two brackets and like 4 screws. When I fixed mine I actually had two problems, one was the screws for the motor and the other was a gum wrapper that somehow got wedge in there knocked it off the tracks. Check the tracks to make sure they're clear. You should be able to get a good look at things by just taking the glass off.
Old Aug 28, 2011 | 02:01 PM
luvboost's Avatar
do you know how to take the glass off?
Old Sep 2, 2011 | 01:44 PM
AWD96's Avatar
The glass comes out by 2 torx bit screws on each side of the glass. Its easy, i have had my headliner down and a new sunroof motor in with about 30mn of time realistically.
Old Sep 2, 2011 | 04:14 PM
luvboost's Avatar
nice, good to know. I think I'm gonna do this on my next days off. I saw those screws so I'll take em out as soon as I get some extra time.
Old Dec 9, 2011 | 04:41 PM
Stock-ish's Avatar
more sunroof issues
iv already pulled my headliner, and the entire sunroof track..
not sure why but my track seems to be sticking so bad its grinding the teeth off the motor.
after cleaning and lubing the whole thing and reinstalled, im still getting the same issue.
need help. please help
Old Dec 10, 2011 | 02:39 PM
wizzo 8's Avatar
Did you look at the sunroof motor at the back? Did you find the screws loose?
Old Dec 10, 2011 | 05:08 PM
Stock-ish's Avatar
yes, both screws fell out of the headliner as i took it out....pushed the roof all the way open and had the motor in the full open position. tested it many times.
but thats the thing, it was working good rite off the bat. so i put the liner back in and called it a day.
a few days later i hit the switch and it skips teeth again. took the headliner out again. then. found that even with the motor removed, the roof was hard to open. since iv removed the whole track from the car in an attempt to clean and relube.
still works like crap.
Old Dec 11, 2011 | 06:36 AM
wizzo 8's Avatar
Sounds like you need new new worm/screw cables then.
Old Dec 11, 2011 | 07:46 AM
Stock-ish's Avatar
so be it, if they are bad. a friend and i are going to attempt to overhaul the entire track. im thinkin pine sap dripped in the track. if all else fails il order up new parts. i may seal it up for the winter if it still works like crap.
Old Dec 12, 2011 | 07:02 PM
luvboost's Avatar
how are you gonna seal it up? I think that's what I'm gonna do with mine. Mine sounds like it's grinding teeth also but I don't have time to remove it. I think I may have to seal it up for winter also. It's closed but keeps sinking down after a bit of driving enough to where moisture can get in so I have to push it back up.
Old Dec 18, 2011 | 11:18 AM
Stock-ish's Avatar
^ do you see it leaking? there are drains at all corners. i slid my roof closed by hand with the motor disconnected. it doesnt go up in the back all the way but good enough not to leak.
Old Dec 19, 2011 | 06:28 PM
luvboost's Avatar
I'll have to check this out later if there are pics. I can't see any at work.
Old Mar 28, 2015 | 01:16 AM
cmiller10's Avatar
time to revive an old thread. does anyone know the sizes to the sunroof screws. I plan on taking a look at mine in the next few days and was wanting to get the sizes incase I need to buy new ones. thanks in advanced. also what do you all use to lube the tracks?
Old Oct 8, 2015 | 06:04 AM
luvboost's Avatar
short answer to my original question is NO. I was also asking the wrong question... It never fell off the tracks. It was the motor behind it that came loose. I never lubed my tracks but I'm sure that info is somewhere. The screws just literally came out of the motor and when I pulled the headliner they were all right there. I thought the glass had came off the tracks and it felt that way but I was wrong. What are your symptoms?
tsidrift1
For Sale - Part Outs
Apr 14, 2017 08:32 AM
Shinzon
For Sale - Cars For Sale
Aug 29, 2016 11:42 AM
evowill88
34
Dec 25, 2015 02:02 AM
Jimbolution
Nov 16, 2015 04:58 AM
RoumKoTeam
Nov 2, 2015 04:42 AM
