Problems-hesitation and coughing
2003 stock evo VIII
Hesitates on hard acceleration between 3500 & 4000 rpms.
Coughed this morning in 4th gear when I tried to pass a semi-truck.
No engine error codes.
Please help.
Please help.
This could be a host of things. Very good advise above...I just went through similar problem. Mine turned out to be the stock fuel pump circuit. I obtain a DW 300 fuel pump..same problem so I hard wired the pump...same problem. The problem got worst....the car would stall. I would let it set for awhile and then it would start. This time I put my own hard wire circuit, bypassing the stock three relays and resitor. New relay....fused straight from the battery.......retune....all is good now. Have no idea if this is your problem, but something to think about. Good luck!
I spoke too soon! Now it's starting when it wants too? Just started this again to day. I can hear the pump running, but no start issue. Nuts!
