Evo is misfiring ... suggestions?
Old Sep 5, 2011 | 08:47 PM
novem's Avatar
Originally Posted by 4RETECH
You can gap any plug. Be it copper, iridium, or platinum .You just have to be careful at it. That's why there are specs for every car. Plug manufacturers just gap to a general range. Plus I never trust them out of the box, you every check the difference in gap!
To the OP, gap to .22
Ohm out the spark plug wires too
Iridium spark plugs are not supposed to be gapped because they have platinum on the ground strap. When you gap them, you scrape the material off. That's why they say not to gap them.
N
Old Sep 6, 2011 | 12:16 AM
73DatsunZ's Avatar
Battery and alternator are both good. The starter is bad come to find out, and also it threw a CEL for the Crank Position Sensor tonight. Finally a lead to the issue. Got a new one ordered and will be fixing the car this weekend when it arrives.
Old Sep 6, 2011 | 07:42 AM
4RETECH's Avatar
N
http://www.ngk.com/glossary.asp?kw=S...gs?&manID=1&pt=
Wow, I'm glad you found something. Good Luck and let us know how you made out.
Old Sep 18, 2011 | 02:50 PM
73DatsunZ's Avatar
Ok so after a couple weeks I am becoming irritated.
The car will fire up, but now its idling not so well. When you rev it a little it fumbles on itself.
I put a brand new crank angle sensor in the car, had it retimed and its still having the same freakin issue.
What has been done:
- New crankshaft angle sensor
- Put known good MAF in
- OEM heat range plugs, and step colder plugs (varying gap)
- New Walbro Pump
- Put known good coils on with known good wires
- Cleaned contact points for both cam sensors
- All vacuum lines are connected properly
Im beginning to think it may be my stock injectors being faulty because I cant think of anything else.
I have a new set of FIC 950cc plug & play injectors in the garage.
Evo gurus advice?
Old Sep 18, 2011 | 03:29 PM
xRoguex's Avatar
When you swapped coils -- did you swap wires too -- or just the coils?
Old Sep 18, 2011 | 04:13 PM
novem's Avatar
That's a great picture showing how the material gets scraped off in the gapping process
That's exactly how the material gets scraped and the plug ruined! Good find!
N
Old Sep 18, 2011 | 04:38 PM
zeus1's Avatar
not to thread jack but if i purchase iridium plugs (step colder for my car) and they come pregapped to .032 then i should be fine running these when i gap copper plugs to .022??
http://www.rallysportdirect.com/NGK-...rce=GoogleBase
Old Sep 18, 2011 | 08:23 PM
73DatsunZ's Avatar
Yes I swapped the wires as well.
Old Sep 18, 2011 | 08:44 PM
Evolution8.5's Avatar
Are you loosing coolant by chance and did you check your timing just cause you got a crank sensor fault doesn't mean the sensors bad and it's clearly not ignition related check your injectors and check if your loosing coolant slso as dumb as this sound try putting different gas in the car you would be amazed at how many cars come to the shop misfiring due to bad gas
Old Sep 18, 2011 | 09:40 PM
heavens turbo's Avatar
do you have a scantool to monitor sensor values? it sounds like it's in the closed loop circuit. no codes? maybe tune? good luck.
Old Sep 18, 2011 | 09:52 PM
Nashou66's Avatar
try the spare injectors yours might be dirty and sticking .
Athanasios
Old Sep 18, 2011 | 10:02 PM
xRoguex's Avatar
yours sounds like mine did - only mine went from good to fubard all at once.
Im still leaning towards ECU.
Old Sep 22, 2011 | 08:16 AM
mission664's Avatar
N
NGK says different
http://www.youtube.com/watch?v=lk70oyUEftY
Old Sep 22, 2011 | 09:13 AM
Ev0ikon's Avatar
There is the right way and there are wrong ways to gap the Iridium plugs. Try not to put pressure on the tip is all.
Old Sep 22, 2011 | 09:33 PM
novem's Avatar
Gap vid
Originally Posted by mission664
You'll notice in the " right way" part of the video he slides the gap tool in and out, before he pulls back on the ground strap. When you slide the gap tool like that, you are scraping the platinum off right where you push and pull the tool back and forth.
That's not going to work. You may not scrape a lot of material off, but I would not take a chance of wasting money ruining a plug like that.
N
