brake help
Old Sep 14, 2011 | 03:03 PM
Bizo2's Avatar
brake help
Just installed hawk HP plus pads, but I'm getting very loud squealing from the driver side only. I've put the lubricant (plenty of it) but still getting very loud squeal. Also the shimes have arrows on them, which way are the arrows suppose to go?
Any suggestions would greatly be appreciated
Old Sep 14, 2011 | 03:48 PM
dastallion951's Avatar
iirc the arrow should face the front, you might have that pad with the shims in backwards...?? my hps are noisy at times, there also dusty pad so maybe built up brake dust is causin it...?? Did you turn the rotors or replace them when puttin them on?
Old Sep 14, 2011 | 03:55 PM
Raptord's Avatar
Arrows should be pointing the same way the wheel rotates while moving forward.
Old Sep 14, 2011 | 10:39 PM
Bizo2's Avatar
the arrows can only face up or down. Put the pads on last week. Didnt do anything to the rotors.
Old Sep 14, 2011 | 10:43 PM
LancerEVA06's Avatar
Pads probably haven't seated yet probably. I have 10K on my pads/rotors and it stopped squealing while braking going forward after a few hundred miles... but when I back up (when they're cold), they squeal like crazy
Old Sep 14, 2011 | 11:10 PM
Bizo2's Avatar
that's the issue, the passenger side is fine, no noise, but the driver side is driving me crazy
Old Sep 15, 2011 | 11:39 AM
barneyb's Avatar
I'm sure Hawk makes very good products. But, their pads on the brakes that come on our cars are noisy. Sorry.
Old Sep 18, 2011 | 07:22 PM
kurdy's Avatar
I have the same pads, and it only makes noise when it cold then it goes away.
