Please help - P0505 returns
Old Sep 23, 2011 | 11:47 PM
Temujin's Avatar
The car throws this CEL code P0505 for a month. Went to the mechanic, said it was the IAC valve.
Ordered the MD628318 part, first one that arrived had the smaller head, sent it back. Yesterday I received the correct part, the mechanic replaced it, cleared the CEL. He didn't reset the ECU though...
No CEL on board until the evening, when I left the office. On my way home, the darn CEL came up again.
I couldn't be more pissed... What else can generate that code? How can I find out? Could be a boost leak or...?
Any help will be appreciated. Thanks!
Old Sep 24, 2011 | 05:24 AM
studioface's Avatar
Found this for you.
CEL = P0505 = Idle Air Control Motor (IAC) circuit condition or idle speed higher/lower than expected.
Definition: IAC circuit condition or idle speed higher/lower than expected.
Explanation: The ECM has detected that the IAC counts are higher or lower than expected, the engine speed is not its expected range.
Probable causes:
1- Vacuum leak on the engine
2- Dirty throttle body
3- IAC motor is defetive
4- Poor electrical connection to the IAC valve.
I got this after install the catch can (I removed the throttle body and manifolds). Went back unplugged, and re-plugged everything, checked for boost leaks, made sure everything is seated properly, and checked the tightness of all of the screws. Reset the code by unplugging the battery and I haven't got it since (300miles ago). IMHO I'd start there.
Old Sep 24, 2011 | 11:51 AM
EVO8STI's Avatar
^ nice wish i had a explanation like this for all my problems
Old Sep 26, 2011 | 01:39 AM
Temujin's Avatar
Hello, thank you for such a detailed answer. Well, the IAC is brand new and just replaced. Truth is the mechanic didn't reset the ECU after changed it nor did he adjust the idle speed in any way.
I will go with the car to the mechanic and start all over again.
Thanks again!
Old Jun 9, 2012 | 08:14 AM
05whiteRS's Avatar
I am having a similar issue. I recently had my intake manifold and throttle body ported and while everything was off I removed the EGR system. I capped off everything on the IM from the EGR and installed the blockoff plate. Now the car starts and idles fine, but the second I get into boost I get the P0505 code. I can drive around all day without getting into boost and no error code. I've removed the IAC and made sure the seal is installed properly and the connector is tight. Any ideas?
thanks,
Old Jun 9, 2012 | 08:40 AM
Temujin's Avatar
thanks,
OK, last year I went through this for like two months without any fix. I've ordered a brand new IAC valve from U.K., replaced it, the garage mechanic cleared the CEL... only to have it back on board 15 minutes later, after the first WOT.
I was about to give up - as a last solution I took a ride to the Mitsubishi dealer service to have the car checked. 30 minutes later it was absolutely fine, the CEL never came back.
In my case, it was the air-flow meter, they checked it and adjusted as I was told. Have that thing inspected by a qualified technician in your area if you can.
HTH
Andrei
Old Jun 12, 2012 | 06:00 PM
05whiteRS's Avatar
any other ideas? Could it be a tuning issue? Could it have something to do with removing the EGR?
Old Jun 12, 2012 | 08:32 PM
Anarchy99's Avatar
Probably not the IAC/ May be a vacuum leak causing a raised idle.
Old Jun 13, 2012 | 06:35 AM
05whiteRS's Avatar
That seems to be the common cause. I've looked it over and over and could not find any leaks. Could removing all the EGR without updating the tune to "pass" the EGR test cause this?
Old Jun 13, 2012 | 05:16 PM
Anarchy99's Avatar
Usually you would get a p0401 or EGR code if that was done.
DSMolition
Dec 28, 2015 07:15 AM
06evol
For Sale - Cars For Sale
13
Oct 12, 2015 01:51 PM
foxbear2277
Dec 15, 2013 05:49 PM
EVOlutionary
Jan 27, 2012 08:00 PM
jack1526
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 11, 2011 07:48 PM
