3 acd lights on
Old Sep 24, 2011 | 12:56 PM
walshly's Avatar
3 acd lights on
hi all 3 acd lights keep going on on me evo 8 got it tested an code 82 pump fail came on garage man said wud be 550 to recondition pump an do the work priced around and can get reconditioned one 4 250 any ideas on how i can to replace the pump myself thanks
Old Sep 24, 2011 | 01:25 PM
BenJ's Avatar
It is a bolt on affair, nothing crazy. Just be sure to put in new fluid and bleed it.
Old Sep 24, 2011 | 01:57 PM
svt_lightning01's Avatar
When it happened to me i put fluid in it and it went off immediately
Old Sep 24, 2011 | 05:06 PM
WolfsFang's Avatar
How do you flush the fluid out? My 3 lights have been on for like 4 months now.
Old Sep 24, 2011 | 05:19 PM
sti45007's Avatar
Yes, I would be interested in knowing this as well. Seems like such a common problem of the acd pump failing that you would think their would bean aftermarket replacement part or rebuild kit. Whoever figures out an inexpensive repair will be rolling in the $$.
Old Sep 24, 2011 | 05:32 PM
BenJ's Avatar
An inexpensive fix would be to just buy a used one, there are plenty out there. Also, like someone else mentioned, make sure that you have enough fluid first and foremost.
Old Sep 26, 2011 | 04:03 PM
Schmidty7's Avatar
having a similar problem but mine only come on every so often. any ideas?
Old Sep 26, 2011 | 04:23 PM
ProPilot04's Avatar
Are any of you driving on tarmac, covered in gravel, covered in snow?
Be advised... my contributions to society are largely on the level of useless.
Old Sep 26, 2011 | 04:38 PM
HN7's Avatar
HN7
Me lol. Weird thing is my issue have something to do with the wiring of some sort. I got a code 82 (pump failure) but it still works when the weather is cold (70 and below), but then sometimes it wouldn't.
Old Sep 26, 2011 | 05:43 PM
njboy's Avatar
My ACD pump started making strange noises after I drove through high water a few months ago. I wonder if it's damaged? These pumps seem to go out before 100k miles for a lot of people. Would be great if someone could dissect this unit and figure what is failing prematurely.
Old Sep 26, 2011 | 06:34 PM
killerpenguin21's Avatar
search around here, its been done. if i recall basically they are just not sealed well and corrode to **** inside. i believe a company in the UK rebuilds them and/or sells necessary parts.
Old Sep 30, 2011 | 08:27 AM
WolfsFang's Avatar
How do you guys pull the code for the problem with the pump? Do you go to a dealer? For somereason my ace decided to work today going to work. I don't know id its weather related or what.
Old Sep 30, 2011 | 08:38 AM
4RETECH's Avatar
ACD should be bled with the mitsu tester. But if you don't it's a two person thing.... Just don't run the pump low or you might burn it out..
Old Sep 30, 2011 | 08:53 AM
HN7's Avatar
HN7
Mine is doing the same thing. I got a code 82 but it just work when it wants to. It was 65 earlier when I left the house, went 20 miles with it working perfectly. But as soon as the temp outside reach 80-90, bam, all lights come on.
Here's the how to to get the ACD code:
Get a paper clip and use it to bridge pins 1&4 on your obd
(diagnostics plug) as you sit in the driver seat its in front of your right knee,
when the paper clip is in place turn the key on (dont start the car)
if there are no faults codes the 3 acd lights will flash rapidly.
and if there is fault codes, the 3 lights will flash slower
for example fault code 65
there will be 6 long flashes slight pause followed by 5 short flashes,
simply count the long flashes as 10 : 6x10=60
and the short flashes as 1 : 5x1 = 5
together that's code 65
there may be more than one code.
Quote:
here are the acd/abs fault codes
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system
Old Oct 1, 2011 | 07:40 AM
Lucas19800's Avatar
I had the very same problem,
It turned out I had an unstable connection between couple of pins in the ignition circuit. It was also causing the ABS light to come on. I think that was a code 65.
H_o_B_o
Jan 25, 2017 01:12 AM
honda-guy
14
Dec 28, 2015 04:49 AM
TTP Engineering
50
May 12, 2009 12:29 PM
piotr4net
14
Sep 26, 2008 10:58 AM
Thoe99
12
Aug 31, 2005 02:01 PM
