Choosing camshafts !! HELP!!
Old Nov 2, 2011 | 01:08 PM
  #46
Levar's Avatar
Veteran: Army
Originally Posted by mikeywick821
Another question, is there anything wrong with getting Manley springs and retainers, as opposed to the GSC Beehive ones? or do they all work the same?
Do springs work the same? Yes. Are some springs better suited than others? Yes. The beehive design is a newer concept as opposed to the traditional springs. The beehive spring utilizes ovate shaped wire that more effectively distributes stress over the entire wire area in comparison to a typical round wire spring. In simple terms, the design is able to suit higher lift cams that improves valve control and reduces fatigue of the spring.
Old Nov 2, 2011 | 09:28 PM
  #47
mikeywick821's Avatar
Okay that makes sense. thanks for your advice again =)
Old Nov 3, 2011 | 05:13 AM
  #48
Levar's Avatar
Veteran: Army
No problem, my friend.
