120isn Compression test on all 4... suggestions
Old Oct 5, 2011 | 09:07 AM
ProudEvo8Owner's Avatar
I decided to do a compression test on my car and the numbers I got were low from what I have seen from most evos. I got from left to right 120 122 122 130. I have 91k miles on my engine and I was hoping to make put some mods on my car, but after doing this test, is it really neccesary to do an overhaul?
I am pretty much stock, all I have is a hks intake and a walbro 255. I have 272/272 hks cams sitting in my garage waiting to put them in.
Old Oct 5, 2011 | 09:31 AM
AWDBus's Avatar
In my experience, as long as all the numbers are close, things are good. Its when you see a big drop in one or two cycs. is when you worry.
Every tester is different, even same brands can be a few psi off.
Old Oct 5, 2011 | 12:27 PM
Aby@MIL.SPEC's Avatar
run it!
Old Oct 6, 2011 | 12:18 AM
Teal2nnr's Avatar
Dude its fine, the numbers are close to eat other. Did you do it when the engine was cold or warm?? this makes a difference as well.
Old Oct 7, 2011 | 10:06 AM
MechTech's Avatar
wet or dry numbers and did u have the throttle plate propped open?
Old Oct 7, 2011 | 11:31 AM
1UpMoto's Avatar
Originally Posted by Aby@MIL.SPEC
run it!
x1000
Old Oct 7, 2011 | 11:39 AM
NewEvolutionIX's Avatar
Stock compression is 145 cold at WOT. But you can run it fine. I have a P0011 code, my compression is 110 on all cylinders, but Im making 100 less whp bc of it.
Spoolin4g63
Feb 25, 2013 11:28 PM
FL_SilverEvo8
30
Mar 31, 2012 04:22 PM
Throttle
20
Jan 21, 2012 07:41 AM
e4on2e5
62
Jul 28, 2011 10:52 AM
midwestmonster
For Sale - Cars For Sale
Jan 20, 2011 06:56 PM
