Best turbo for 2.3 stroker
Old Oct 9, 2011 | 08:54 PM
EvoJoeIX's Avatar
Originally Posted by localtoys73
he wants a lagier turbo that makes less power
if you are going turbo kit hta86 is your best bet and I have had all 3 turbos.
I hear that, thats why i asked him why. Lol
Old Oct 9, 2011 | 09:08 PM
NewEvolutionIX's Avatar
Im doing a 2.4 with the HTA3586
Old Oct 10, 2011 | 03:57 AM
alenewit3928's Avatar
how does the 6262 make less power than those three turbos
Old Oct 10, 2011 | 04:03 AM
Which turbos spool faster and makes more power than the black and 6262?
Old Oct 10, 2011 | 05:54 AM
CBRE's Avatar
Originally Posted by CBRE
BB FP Green or Red
On my car is has a hint of lag then overwhelming hit of power unsettling the car, at least for my set up it makes the car to fast for twisty back road burns that I enjoy, with no timing and 22psi on a hot day the BB Black made 522whp on Buschurs dyno on my car, now with the cooler weather boost hits 27 and tapers to 25 on WG and its borderline rediculous. Forgot to mention at the shootout with a peak boost of 23.9 it ran 10.8@137 rolling it off the line and major granny shifting(had clutch issues that day) in the heat. Maybe im just getting old but I like the Green right around 28psi.
Old Oct 10, 2011 | 06:03 AM
Which turbo do you think is best for stroker?
Old Oct 10, 2011 | 06:07 AM
thepoint4life23's Avatar
look at daivd buschur dyno sheet for his car with the rpm2.3l motor. its nuts also look in to the new bb6265
Old Oct 10, 2011 | 06:24 AM
S13 Curtis's Avatar
HTA86 is perfect.
Old Oct 10, 2011 | 06:27 AM
Originally Posted by S13 Curtis
HTA86 is perfect.
I thought the HTA86 and the PT6262 were like the same.
Old Oct 11, 2011 | 03:52 AM
Levar's Avatar
Veteran: Army
I have would have to say the EF3 and 73HTA Green respectively.
Old Oct 19, 2011 | 04:55 PM
How much power will the hta green make?
Old Oct 19, 2011 | 05:00 PM
S13 Curtis's Avatar
PT6262 has an 82mm exducer
HTA3586 has an 86mm exducer
Old Oct 19, 2011 | 05:05 PM
I really don't know which turbo to get. I want a decent power-band. 2.3 only revving to 8400.
Old Oct 19, 2011 | 05:06 PM
David Buschur's Avatar
Check the thread I put up today in the Dyno section, three turbos tested on my 2.3.
Old Oct 19, 2011 | 05:27 PM
Thanks a lot
