Upgrade Intercooler or wait?
Old Oct 10, 2011 | 01:13 PM
mll's Avatar
mll
If I put on a FP Black turbo, would I need to upgrade the intercooler or would the stock one be good for about a year?
Old Oct 10, 2011 | 02:13 PM
thedru13's Avatar
I would upgrade.
Old Oct 10, 2011 | 02:35 PM
DJAfterShok's Avatar
Ummm.... Deff upgrade!!!
Make sure you know what your doing and have enough money to buy the rest of the supporting mods. If anything buy all the supporting mods first and then get the turbo... just my 2 cents...
Old Oct 10, 2011 | 02:40 PM
mll's Avatar
mll
i have the turbo and grtting a stroker engine just didnt know if i could wait to get the inter cooler thanks guys
Old Oct 10, 2011 | 02:50 PM
Rmeister007's Avatar
Well, if you upgrade the turbo, you'll wanna run higher boost, right? Having an upgraded cooler allows you to run higher boost. Otherwise, you'll be running less when it gets tuned. Since you have to tune it anyways, you might as well spend the extra $500 on the intercooler and do it right the first time instead of tuning it twice, y'know?
Old Oct 10, 2011 | 02:56 PM
mll's Avatar
mll
so i can just get a inter cooler i dont have to get a hole kit?
Old Oct 10, 2011 | 03:17 PM
When are you getting your stroker?
Please list your CURRENT mods you have on the car.
Old Oct 10, 2011 | 03:19 PM
njboy's Avatar
I have just a TBE and wanted to get the most aggressive tune without knocks so I got an intercooler. Must say it makes the boost far more reliable without worry of knocking. So in your case I would say definitely!
Old Oct 10, 2011 | 03:27 PM
mll's Avatar
mll
272 hks cams, fp black, 1650 injectors,fp 02 housing,ams double fuel pump kit,act 6 puck clutch and i was going to go with ets inter cooler kit but i was just going to by the inter cooler if i can my stroker will be done in february
Old Oct 10, 2011 | 03:35 PM
D&M Auto Salon's Avatar
My car made 465awhp on a 2.3 with a MAP EF3 turbo on the stock intercooler and piping on 25 psi
Old Oct 10, 2011 | 03:40 PM
mll's Avatar
mll
so if i boost it low i could get away with it? and thanks for the advice im new here and trying to learn
Old Oct 10, 2011 | 05:26 PM
njboy's Avatar
Boosting low will be safer. Another thing to consider if you don't trust your fuel octane and have hot Sumners the intercooler upgrade is a sound investment.
Old Oct 11, 2011 | 01:08 PM
If those are your CURRENT supporting mods, not bad. It will hold up with a stock intercooler but I'm sure that its restricting the hell out of you. Also if you have stock pipping. It would totally be up to you if you want to wait 2-3 more months when your new motor is build.
Check out the Buschur race core, thats the one I have in my car... Looks sexy ;-)
Old Oct 11, 2011 | 02:23 PM
mll's Avatar
mll
what is the size of the inter cooler pipe and would i be ok to just get the inter cooler and and use stock pipe
Old Oct 12, 2011 | 02:50 PM
desiromeo812's Avatar
I would at the minimum Upgrade the LICP. the Upper piping should be upgraded but its not needed. As far as the intercooler, I run the Buschur Deluxe Fmic, really makes the car look better and temps are cooler. Anytime you have a bigger turbo than stock I would upgrade the FMIC.
Even with stock Turbo there are Gains to be had if you push it enough with Aftermarket FMIC
