Major electrical problem?
Old Oct 11, 2011 | 02:41 PM
prowakeskater's Avatar
Hey all, looks like I may have stumbled upon a world of ****.
I recently spliced a nest of wiring for a viper alarm/remote start. Installation went great, had everything neatly arranged and working perfectly until recently when my battery started dying overnight.
So I picked up a multimeter and read some post a google search that recommended to hook up the meter between the negative cable and the negative battery terminal, which I did.
To my amazement, I found a full 12v reading So I did what was recommended, which was to pull every fuse and anything powered and watch for the voltage to drop or disappear. Unfortunately, with the alarm brain out along with all the fuses, the reading is still holding strong
how should attack this? Am I correctly positioning the multimeter the way I described? The battery was brand new 3 months ago so I'm not sure if I have always had this problem, or if it just manifested from the installation. Please help
Old Oct 11, 2011 | 02:47 PM
ok, looks like I was using volts not amps. Im really sick of finding answers seconds after I make a thread.
Old Oct 11, 2011 | 03:27 PM
looks like my LC-1 is drawing 2 amps! WTF
Old Oct 11, 2011 | 04:02 PM
ProPilot04's Avatar
How is your LC-1 wired? Is it fused?
Old Oct 12, 2011 | 06:39 PM
I had it hooked up all wrong. I had the red, 12v power wire hooked up to a constant 12v source
luckily my battery was warrantied..
